Mass of used hydrogen in an isothermal process
The discussion revolves around calculating the mass of hydrogen used in an isothermal process from a 12 L tank at 15°C with a pressure change of 0.4 MPa. The equation proposed for the calculation, Δm = (M/RT)VΔp, is confirmed as appropriate, though there are concerns about unit conversions. The initial calculation yielding approximately 4 kg is questioned, leading to a clarification that the molar mass should be expressed in kg/mol rather than J/(mol*K). After correcting the value for the gas constant R, the participants arrive at a more accurate result. The conversation highlights the importance of unit consistency in thermodynamic calculations.
Uku
I have hydrogen in a 12 L tank, at T=15 C. Some of it is used, the T = const. and Δp=0.4 MPa,
the molar mass of hydrogen is M=2*10^-3 J/(mol*K). Find the mass of the used hydrogen.
Am I wrong in simply using:
\Delta m=\frac{M}{RT}V\Delta p ?
That gives roughly 4 kg's..
Thanks,
U.
Hi Uku,
The equation you have used is appropriate. You could have gone wrong in the units, though.
By "could have" you mean you put in the numbers and got a different answer?
No, I didn't put in the numbers. I was just confirming the equation use :smile:
Though, 4 kg does seem a bit too much...:rolleyes:
The answer is different from yours. What number did you use for the volume? And the molar mass is 2*10-3 kg/mol, not J/(mol*K):-p
Well the pressure differential is 0.4 MPa..
The pressure is all right, but what number have you plugged in for volume?ehild
0.012 m3
Well, then plugging in all data,
Δm=(2*10-3*0.012*0.4*10-6)/(8.3145*288)=9.6/2394 how can it be 4 kg? :confused:
ehild
I messed up on R, since I wrote R=8.314*10^{-3}\frac{kJ}{K} when trying to write R in terms of kJ.
That I did not guess. Why in kJ-s?
But You got the correct result at the end now? :biggrin:
ehild
