Mass pulled on a rotating disc
In summary: I mean required...step in homework.)The tension in the wire at t=0 is the centripetal force+force due to linear acceleration:$$F=m(\omega_0^2R+a_0)$$The tension in the wire at t=0 is the centripetal force+force due to linear acceleration:$$F=m(\omega_0^2R+a_0)$$The angular velocity ω without the nail is from conservation of angular momentum.$$I=\frac{1}{2}MR^2##The angular velocity ω without the nail is from conservation of angular momentum.$$I=\frac
Karol
1,380
A disc of radius R and mass M lays on a smooth table. a smooth channel is carved along the diameter and on both ends there are masses m. one of the masses is attached with a wire to a small, almost weightless motor that is in the center. the other mass remains fixed in place. the disc can rotate round it's center using a smooth nail.
At t=0 the disc rotates at ω0 and the motor starts pulling the left mass with acceleration a0. what is the tension in the wire.
Now the nail is removed and at t=0 the disc again rotates at ω0 and the motor running. find the distance s(t) of the center of mass of the system relative to the center.
What is the angular velocity of the disc as a function of time. use s(t).
What is the tension in the wire at t=0
Centrifugal force: ##F=m\frac{v^2}{R}##
Moment of inertia of a disc: ##I=\frac{1}{2}MR^2##
Distance with constant acceleration: ##s=\frac{1}{2}at^2##
The tension at t=0 with the nail is the centripetal force+force due to linear acceleration:
Moments round the left, moving, mass gives the C.O.M. distance s(t):
$$m\left( R+\frac{1}{2}at_0^2 \right)+M\left( \frac{1}{2}at_0^2 \right)=(M+m)\left( \frac{1}{2}at_0^2+s \right)$$
$$\rightarrow s(t)=\frac{a_0 t^2}{4}$$
I consider, for the last term on the right side of the equation, the distance of each mass from the new C.O.M.
$$\frac{1}{2}M\omega_0^2 R^2+2mR^2\omega_0^2=\frac{1}{2}M\omega^2+2m\left( \frac{R+s(t)}{2} \right)^2$$
$$\omega_0^2 R^2 \left( \frac{M}{2}+2m \right)=\omega^2\left( \frac{M}{2}R^2+2m\left( \frac{R+s(t)}{2} \right)^2 \right)$$
I think the tension force at this situation is similar to the first when the nail was.
I'm a bit confused: if the motor is on the disc, why would the CoM move when the nail is removed?
The CoM doesn't move when we remove the nail, i am asked about the distance of the CoM from the center.
Okay. By "center" you mean the center of the disk right?
I take it a0 is constant the whole time?
There seems to be two interpretations of what a0 could mean. (Maybe someone can point out why one is more reasonable.)
One interpretation, which you took, is that ##a_0=\ddot r##
The other interpretation is that a0 is the total radial acceleration (that is, it includes the centripetal acceleration).
From the first interpretation, we get your equation, ##F_{tension}=m(\omega ^2R+a_0)##
From the second interoperation, the tension is more trivial, ##F_{tension}=ma_0##
But for s(t), the second interpretation makes it much more interesting because ##\ddot r## is not constant.Anyway sorry for responding without properly looking at your work, but I have to go to a jazz thing for music class. I'll be back later if the problem is not cleared up by then.
[edited to fix latex]
You cannot take angular momentum to be conserved about an accelerating reference point.
As Nathanael notes, taking a0 to be relative to the groove makes finding s(t) simple. Just consider that the mass centre of the system is fixed, and calculate that mass centre from the known relative positions of the three objects at time t.
Since the question asks for the tension in both contexts, it seems the acceleration should be taken as relative to the groove.
Likes Nathanael
The acceleration a0 is relative to the groove.
The CoM is the origin.
$$\frac{m(R-s)-Ms-m\left[ \left( R-\frac{1}{2}a_0t^2 \right) +s \right] }{M+2m}=0\;\rightarrow\; s=\frac{\frac{1}{2}a_0t^2}{M+2m}$$
You seem to have dropped a factor at the final step. (Checking dimensional consistency is a useful habit.)
$$\frac{m(R-s)-Ms-m\left[ \left( R-\frac{1}{2}a_0t^2 \right) +s \right] }{M+2m}=0\;\rightarrow\; s=\frac{\frac{1}{2}ma_0t^2}{M+2m}$$
If this correct let's continue
Yes, I believe that is right.
So is the rest true? i mean does the angular velocity follow what i have written in the OP:
There seem to be a few problems with the expression for the angular momentum at time t.
The first term is missing any radius factor, and I see no alowance for the fact that the disc is not rotating about its own centre.
I also think the 'm' term is wrong. Safer to consider each mass separately.
The disc's moment of inertia after the nail is removed-shteiner's theorem: ##I_M=\frac{1}{2}MR^2+Ms^2##
$$\frac{1}{2} M \omega_0^2 R^2+2mR^2 \omega_0^2=\omega^2 \left\{ \frac{1}{2}MR^2+Ms^2+m\left[ ( R-s)^2+\left( R-\frac{1}{2}a_0t^2+s^2 \right)^2 \right] \right\}$$
Looks right except for a typo... an extra power of 2 on the last occurrence of s.
Likes Karol
Thanks.
$$\frac{1}{2} M \omega_0^2 R^2+2mR^2 \omega_0^2=\omega^2 \left\{ \frac{1}{2}MR^2+Ms^2+m\left[ ( R-s)^2+\left( R-\frac{1}{2}a_0t^2+s \right)^2 \right] \right\}$$
But what about the last part, what is the tension in the wire? i don't have a clue so i think it should be the same as when the nail was.
Karol said:
Thanks.
Not sure, but where it says "use s(t)" it might mean that the answer should not reference t directly at all. You can replace t using s. Some simplification may then be possible.
Wrt tension, I think you could consider what the tension would be without rotation and then add the centripetal force.
I consider the non-inertial frame of the accelerating disk. s is the distance of the CoM from the center. the CoM remains in place so the disk with the masses on it accelerate to the left with acceleration:
$$s=\frac{\frac{1}{2}a_0t^2}{M+2m}=\frac{ma_0t^2}{2(M+m)}\;\rightarrow\; \ddot s=\frac{ma_0}{M+2m}$$
The total tension force:
$$F=m\frac{ma_0}{M+2m}+m\omega_0^2R$$
The tension is accelerating the mass relative to the disk. ##\ddot s## is the acceleration of the disk.
It's dalamber's force in an accelerated system, don't i have to add it? if that's correct then i only have to add the force due a0
$$F=m\frac{ma_0}{M+2m}+m\omega_0^2R+ma_0$$
Aren't ##\ddot s## and ##a_0## in opposite directions?
$$F=m\omega_0^2R+ma_0-m\frac{ma_0}{M+2m}$$
That looks good.
Likes Karol
Thanks very (very) much
1. What is the Coriolis effect?
The Coriolis effect is a phenomenon that causes objects to appear to curve when viewed from a rotating reference frame, such as the Earth. It is a result of the conservation of angular momentum and the difference in velocities between points on a rotating disc.
2. How does the mass of an object affect its motion on a rotating disc?
The mass of an object does not affect its motion on a rotating disc, as long as the object is not experiencing any external forces. This is due to the principle of inertia, which states that an object will maintain its velocity and direction unless acted upon by an external force.
3. What is the relationship between the radius of the disc and the speed of rotation?
The speed of rotation is directly proportional to the radius of the disc. This means that as the radius increases, the speed of rotation also increases. This relationship is described by the equation ω = v/r, where ω is the angular velocity, v is the tangential velocity, and r is the radius.
4. Can an object experience both centripetal and Coriolis forces on a rotating disc?
Yes, an object can experience both centripetal and Coriolis forces on a rotating disc. Centripetal force is a result of circular motion and acts towards the center of the circle, while Coriolis force acts perpendicular to the velocity of the object and is caused by the rotation of the disc.
5. How does the direction of rotation affect the motion of an object on a rotating disc?
The direction of rotation does not affect the motion of an object on a rotating disc, as long as the object is not experiencing any external forces. This is because the Coriolis force is dependent on the velocity of the object, not the direction of rotation.
