Mass sliding on frictionless inclined plane compresses a spring
A mass slides down a frictionless inclined plane and compresses a spring at the bottom. The energy conservation principle is applied, equating gravitational potential energy to spring potential energy. The initial separation distance, d, is derived from the equation d = (kx^2)/(2mgsinβ) - x, accounting for the incline angle and the distance x the mass travels while compressing the spring. Some participants debated whether to include the distance x in the equation, ultimately agreeing that it is necessary for accurate calculations. The final expression for d reflects the relationship between the spring constant, mass, incline angle, and compression distance.
Nacho Verdugo
A body with mass m start from repose and slide along a plane without friction. The plane forms an angle with the horizontal. After sliding a distance d unknown, the mass touches the extremity of a spring non compressed and non stretched with no mass. The mass slides a distance x until a momentary rest by the compression of the spring (of constant k). Find the initial separation d between the body and the extremity of the spring.
So first, I tried to translate this exercise from Portuguese, so if some words doesn't make sense, I'm sorry!
The doubts I have is where to define the highness at zero. I tried to put z=0 at the moment when the mass compress the spring, in the momentary rest. Then I used conservation of energy and obtained the following result:
[/B]
Energy A (when the mass start to slides):
E=mg(d+x)sinβ
Energy B (when the mass compress the spring):
E=½kx^2
Considering that there's no friction
E_A=E_B
and I obtain that the distance d equals to:
d=½kx(x-1)
Is it right?
Hi Nacho Verdugo and welcome to PF
:welcome:
d=½kx(x-1)
The idea is correct. Can you show how you got the answer? It should depend on the angle of the incline β.
Likes Nacho Verdugo
:welcome:The idea is correct. Can you show how you got the answer? It should depend on the angle of the incline β.
Hi! So, I just had second thoughts about what I post. The idea is to conserve the energy, right? So the energy in A is : mg(d+x)sinβ and the energy in B is :½kx^2. Conserving the energy I obtain:
mg(d+x)sinβ=½kx^2
⇒ mgdsinβ + mgxsinβ = ½kx^2
⇒ mdgsinβ = ½kx^2 - mgxsinβ
⇒ d= (kx^2)/(2mgsinβ)-x
I think in this solution the distance depends of the incline!
mg(d+x)sinβ=½kx^2
That looks good.
Likes Nacho Verdugo
Moderator note: Changed thread title to be descriptive of the problem: "Mass sliding on frictionless inclined plane compresses a spring"
PeroK said:
That looks good.
But shouldn't it be $$d=\frac {kx^2} {2mgsinθ}$$? Why did you take into account x? The displacement x is traveled by both spring and box, so it is not necessary to add x to equation. Think about the moment that the box touches the spring, until that moment the box's energy will have been changed mgdsinθ and it will transfer this energy to the spring.Thus, it should be $$ mgdsinθ =\frac 1 2(kx^2)$$ and we obtain $$ d=\frac {kx^2} {2mgsinθ} $$
Is there anything I missed?
You missed that the box continues to lose gravitational PE as it compresses the spring, for the distance ##x##.
But you missed as well that the lost gravitational PE is already being transferred in the moment.
Edit: I've just got it by thinking last position of them. There is no problem it should be $$ d=\frac {kx^2} {2mgsinθ} - x $$
