Mass spectrometry - How can you find the mass of the compound?
  • Thread starter Thread starter Horseb0x
    Mass
To find the mass of a compound using mass spectrometry, identifying the parent peak, which represents the unfragmented molecular ion, is crucial. Differentiating this peak from those caused by heavier isotopes can be challenging, and confirming the presence of a parent peak amidst fragment peaks is essential. Employing "soft" ionization methods can help in obtaining the molecular weight without fragmentation. Additionally, integrating techniques like H1NMR, C13NMR, and IR can provide more comprehensive structural insights than mass spectrometry alone. Understanding these methods enhances the accuracy of molecular weight determination in mass spectrometry.
Horseb0x
The obvious way would be to look for the parent peak (the peak caused by the unfragmented molecular ion) at the end of the spectrum but how can you tell the parent peak from one caused by heavier isotopes? Also how do you know if there's a parent peak at all and that all the peaks aren't fragments? Are there any tricks I should know about for finding the molecular weight from the mass spectrum?
Chemistry news on Phys.org
There are ways of performing mass spectrometry that involve "soft" ionization methods that do not result in fragmentation. These methods can be used to determine the molecular weight of the species as only the parent ion will be present. Mass spectra obtained under fragmenting conditions can then be used to deduce structural features of the compound.
Using H1NMR, C13NMR and IR will help a great deal than using Mass spec by itself.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
