Masses placed on platforms, with compressed spring under them.
  • Thread starter Thread starter springwave
    Compressed Spring
Two balls of masses m1 and m2 are placed on platforms with springs of the same force constant and compression. When the first platform is released, m1 reaches its maximum height in 4 seconds. The discussion focuses on determining the time it takes for the second ball, m2, to reach its maximum height. The original attempt to solve the problem neglected the time for the spring to restore its length, leading to incorrect results. Clarification is sought on the behavior of the masses after the springs are allowed to operate, specifically regarding when they lose contact with the platforms.
springwave
Two balls of masses m1& m2 are placed on different platforms, which are subjected to springs of same force constant and same compression. (springs are under platforms, basically like launch pads to fire the balls into the air). When the platform of first ball is released, m1 rises to maximum height in 4 seconds. Find the time in which the other ball will rise to it's maximum height
T1 = 4 s
Spring PE = 1/2 kx2
I tried solving the problem neglecting the time taken for the spring restore it's length,(only considering time of flight, after ball loses contact with platform)
But the answer doesn't seem to match.
I'm unable to calculate time taken for spring to restore it's length.
I hope someone can give me some direction on how to proceed.
Hey...
Do you mean that the ball/whatever leaves the platfrom immediately upon release?
Please clarify, before we can proceed, how each of the masses behaves after the springs are free to operate.
Thanks,
Daniel
The balls are initially at rest on the platforms when they are compressed.
They loose contact only after the spring has restored it's length
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
