Why Isn't $\mathbb{R}$ Working in MikTeX?
  • Thread starter Thread starter flyingpig
The discussion revolves around the issue of using the command $\mathbb{R}$ in MikTeX, specifically addressing the error message related to an undefined control sequence. Participants explore the necessary packages to include for proper functionality and share their experiences as novices in LaTeX.
  • Homework-related, Technical explanation, Exploratory
  • One participant encounters an error when trying to use $\mathbb{R}$, indicating an undefined control sequence.
  • Another participant suggests that the command $\mathbb$ is defined in AMS packages, recommending the inclusion of either amssymb or amsfonts.
  • A novice participant asks how to introduce the necessary package into their document.
  • Multiple participants provide a sample document structure that includes the amsfonts package, which resolves the initial issue.
  • One participant questions whether they are restricted to using only one package and expresses confusion about including amsmath, which they believe does not exist.
  • Another participant clarifies that there is no known limitation on the number of packages and corrects a typo regarding the command for including packages.
  • Participants mention that MikTeX can automatically find and install packages when referenced.
  • One participant acknowledges a typo in their previous message and expresses gratitude for the assistance received.
  • Areas of Agreement / Disagreement
    Participants generally agree on the need to include specific packages to use $\mathbb{R}$, but there is some uncertainty regarding the limitations on package usage and the existence of certain packages like amsmath.
    Some participants express confusion about package commands and their functionality, indicating a lack of familiarity with LaTeX syntax and package management in MikTeX.
flyingpig
On MikTeX, can't enter $\mathbb{R}$
Gives me a statement that says
Code:
! Undefined control sequence.
<recently read> \mathbb
l.14 $\mathbb
             {F}$
No idea what that means?
\mathbb is defined in one of the AMS packages, so you probably have to include amssymb or amsfonts or something like that.
I am a novice in this, how do I introduce that package?
Following should work:
Code:
\documentclass{article}
\usepackage{amsfonts}
\begin{document}
$\mathbb{R}$
\end{document}
Code:
\begin{document}
$\mathbb{R}$
\end{document}
That worked, but am I restricted to only one package? Again novice here.
I tried adding \userpackage{amsmath}, but amsmath doesn't exist. I am trying to add an array here.
thanks
thanks
I'm not aware of any limitation on how many packages can be used. Whenever I include a reference to a new package MiTek automatically finds and installs it. Btw, I noticed a typo in your last post. It should be \usepackage not \userpackage.
Suggestion: the userguides you can find on the web are quite helpful. Just do a Google search and you'll find a number of them.
There is also a Google Latex user group that can be quite helpful:
http://groups.google.com/group/latexusersgroup
Yes you are right, I added an "r". I also have looked online, but I thought there was something wrong with it because it didn't work initially and it was the "r" and I thought the package doesn't even exist.
Thanks
  • · Replies 0 ·
  • · Replies 38 ·
