Why does FullSimplify not work with assumptions in Mathematica?
  • Thread starter Thread starter daudaudaudau
    Mathematica
FullSimplify in Mathematica struggles with certain expressions involving absolute values and assumptions, particularly when simplifying Abs[(x*y)]^2 under the condition x > 0 && y > 0, which returns Abs[x*y]^2 instead of a simplified form. In contrast, FullSimplify successfully simplifies Abs[(x/y)]^2 to x^2/y^2 under the same conditions. Users noted that Mathematica may treat variables as complex unless explicitly stated otherwise, leading to unexpected results. A suggested workaround involves using PiecewiseExpand to handle such cases more effectively. Understanding how Mathematica interprets assumptions is crucial for achieving the desired simplifications.
daudaudaudau
Anyone have an explanation for this? It can simplify the first one but not the second...
Mathematics news on Phys.org
And what about this:
FullSimplify[Abs[(x*y)]^2, x > 0 && y > 0]
the result is still Abs[x*y]^2
But there is no trouble doing this one
FullSimplify[Abs[(x/y)]^2, x > 0 && y > 0]
is simply returns x^2/y^2...
I had similar problems and asked tech support about it - they recommend as a workaround e.g.
PiecewiseExpand[Abs[(x*y)]^2, Reals]
x > 0 && y > 0
Well, if this was an equals sign rather than >, it would need to be a double equqals "==". Not sure what the expression would be for >
flatmaster, I don't understand your remarks about "==" ... it clearly says > doesn't it?
Also, AFAIK Mathematica automatically assumes they are real when you use a comparison operator, i.e. "x > 0" implies "Element[x, Reals]"
I see. When you want to assume that both x and y are real, you simply write ", Reals" ? Because this doesn't work for FullSimplify, e.g.
FullSimplify[Abs[x/y]^2, Reals]
is not the same as
FullSimplify[Abs[x/y]^2, _ \[Element] Reals]
