How Do I Fit the Equation x*y^a = b to Data in MatLab?
  • Thread starter Thread starter 2slowtogofast
    Data Matlab
The discussion revolves around fitting the equation x*y^a = b to a given dataset of x and y values using MATLAB. Participants explore various methods for curve fitting and algebraic manipulation to derive the necessary parameters.
  • Homework-related, Exploratory, Technical explanation
  • One participant expresses uncertainty about how to start fitting the equation x*y^a = b to their data.
  • Another participant suggests using the curve fitting toolbox in MATLAB as a potential resource.
  • A participant mentions using polyfit with a logarithmic transformation, resulting in a linear equation, but seeks clarification on how to proceed from that point to achieve the desired form of the equation.
  • Another participant provides an algebraic approach to rearranging the equation, indicating that it can be manipulated into a form suitable for linear regression, while also noting the limitations of providing a complete solution due to the homework context.
Participants do not reach a consensus on the best method to fit the equation, as multiple approaches are suggested and uncertainty remains about the next steps.
Some participants rely on algebraic manipulation and logarithmic transformations, while others suggest using built-in MATLAB functions, indicating a variety of approaches that may depend on the specific characteristics of the dataset.
Individuals interested in data fitting techniques, particularly in the context of MATLAB and algebraic manipulation of equations.
2slowtogofast
if i am given a data set of x and y values i need to come up with an expression of
x*y^a = b and b are constants
no idea how to get started any help geting started please
You may want to investigate the curve fitting toolbox
http://www.mathworks.com/products/curvefitting/description1.html
yeah i did polyfit(x,log(y),1)
that will return 2 number and ill have an eqn
lny = a1x+a2 it fit a straight line to my data but I am confused on what to do next i need xy^a = b is there another function i should try and use or is this more of an algebraic manipulation type of thing and if so can some one tell me where to start.
There is an algebraic way to solve that. Here is my approach
y^a = \frac{b}{x}
\log(y^a) = \log(\frac{b}{x})
a \log(y) = \log(b) - \log(x)
Since this is the homework forum I can't solve the entire problem for you. However, if you do some arranging you can do a y=mx+b curve fit and solve for your coefficients.
