Matlab ODE45: solving with coefficients that are functions of time
This discussion focuses on solving second-order ordinary differential equations (ODEs) in MATLAB using the ODE solver ode23. The user initially encounters NaN outputs when attempting to use time-dependent coefficients derived from a previous ODE solution. The issue is resolved by correctly indexing the coefficients K1 and K2 as functions of time within the second ODE function. The final implementation ensures that the coefficients are accessed appropriately based on the time variable.
  • Familiarity with MATLAB programming and syntax.
  • Understanding of ordinary differential equations (ODEs) and their solutions.
  • Knowledge of MATLAB's ode23 function for solving ODEs.
  • Ability to manipulate arrays and indexing in MATLAB.
  • Explore MATLAB's documentation on the ode23 function for advanced usage.
  • Learn about indexing techniques in MATLAB to handle time-dependent variables.
  • Investigate the use of anonymous functions in MATLAB for dynamic coefficient calculations.
  • Study numerical methods for solving higher-order ODEs in MATLAB.
Mathematics students, engineers, and researchers working with dynamic systems who need to solve second-order ODEs with time-dependent coefficients in MATLAB.
hasidim
Hello all,
I am new to the ODE solvers in Matlab and am trying to learn:
First, I am solving a 2nd order ODE to determine x(t), x'(t), and x''(t). No problem. Then, I am using these solutions to calculate two coefficients (that are functions of time) that are used in a second, second order ODE. The output solution is a vector of NaN's.
To explain... the first ODE script:
Code:
% Initial Conditions:
x10 = x0;  %x0 is some initial value
x20 = 0;
tspan = linspace(0,tmax+dt, tmax/dt+1);
% Solve ODE
[t,x] = ode23('ode', tspan, [x10,x20]);
and first ODE function (where c1 and c2 are arbitrary, constant coefficients):
Code:
function xp = ode(t,x)
xp = zeros(2,1);
xp(1) = x(2);
xp(2) = c2*x(1)-c1*x(2)
So now I have solutions for x(t), x'(t), x"(t) (that I name x, xp, xp2 respectively).
Ok, so no problem until I get to the second ODE. Following the same approach:
Script:
Code:
a10 = a0;  %a0 is some initial value
a20 = 0;
% Solve ODE
[t,a] = ode23('ode2', tspan, [a10,a20]);
ODE function:
Code:
function ap = ode2(t,a)
K1 = xp2./x;
K2 = xp1./x; % the length of K1 and K2 is the length of x from solution above
ap = zeros(2,1);
ap(1) = a(2);
ap(2) = K2*a(1)+ K1*a(2)
Using the above ODE function, I will get an indicie mismatch error. If I try to apply indices to K1 and K2 [(floor(t/dt)+1)], the output will all be NaN's.
It seems like there should be a simple answer as to how to solve a second order ODE that has coefficients (that are functions of time) that I have already solved for. Thanks in advance. (Hopefully my explanation is clear).
Hi All,
I found my issue. It was with the coefficient calculation, not with the ODE solver.
For what its worth, the coefficients in the second ODE (the coefficients that are functions of time) do need to be indexed as a function of t. So, something like this:
Code:
K1 = xp2./x;
ap = zeros(2,1);
ap(1) = a(2);
ap(2) = K2(t/dt+1)*a(1)+ K1(t2/dt+1)*a(2)
  • · Replies 18 ·
