Matrices - finding critical values
  • Thread starter Thread starter steelphantom
    Matrices
To determine the value of k for which the system of equations has exactly one solution, the augmented matrix is analyzed. The critical point arises when k = -1, leading to a contradiction in the second and third rows, indicating no solution. For all other values of k, the system yields a unique solution. The determinant of the coefficient matrix must not equal zero, which occurs only when k = -1. Therefore, k can take any real value except -1 to ensure a single solution exists.
steelphantom
Find k so that the system has exactly one solution.
\left{ \begin {array} {rcl} x - y + 2z = 1 \\ -x + y - z = 2 \\ x + ky + z = 3 \end {array} \right .
Ok, so I create an augmented matrix here:
\left[ \begin {array} {ccc|r} 1 & -1 & 2 & 1 \\ -1 & 1 & -1 & 2 \\ 1 & k & 1 & 3 \end {array} \right]
Here I do the following: R2+R1 and R3-R1.
\left[ \begin {array} {ccc|r} 1 & -1 & 2 & 1 \\ 0 & 0 & 1 & 3 \\ 0 & k+1 & -1 & 2 \end {array} \right]
R2 <=> R3.
\left[ \begin {array} {ccc|r} 1 &amp; -1 &amp; 2 &amp; 1 \\ 0 &amp; k+1 &amp; -1 &amp; 2 \\ 0 &amp; 0 &amp; 1 &amp; 3 \end {array} \right]
(1/k+1)R2.
\left[ \begin {array} {ccc|r} 1 &amp; -1 &amp; 2 &amp; 1 \\ 0 &amp; 1 &amp; -1/(k+1) &amp; 2/(k+1) \\ 0 &amp; 0 &amp; 1 &amp; 3 \end {array} \right]
At this point, I'm stuck. How do I know which k will give the system exactly one solution?
Is your first equation correct? It does not match with your matrix.
Have you learned about eigenvalues?
Sorry; I just fixed it. Everything should be correct now. We haven't learned about eigenvalues yet.
Would reducing your matrix all the way to the identity matrix help?
We haven't even gone over the identity matrix yet. :redface: I think I may have come up with a solution:
OK, in this form, if k = -1, the second and third rows would be contradictory (i.e. no solution):
\left[ \begin {array} {ccc|r} 1 &amp; -1 &amp; 2 &amp; 1 \\ 0 &amp; 0 &amp; 1 &amp; -2 \\ 0 &amp; 0 &amp; 1 &amp; 3 \end {array} \right]
However, if k were anything else, there should be exactly one solution, right? So is the answer all real numbers except -1, or am I totally off-base here?
Looks like 'a' solution. How would you know if there were others, or not?
The identity matrix has ones on the diagonal, & zeros everywhere else. Basically continue your reduction method, or back-substitute from where you are, to obtain complete expressions for x,y,z in terms of k & then make a decision.
This will give you the full solution for x, y, z & you could then re-check your current solution.
Ok, I've reduced my matrix to the identity matrix. Here are my steps:
\left[ \begin {array} {ccc|r} 1 &amp; -1 &amp; 2 &amp; 1 \\ 0 &amp; k+1 &amp; 0 &amp; 5 \\ 0 &amp; 0 &amp; 1 &amp; 3 \end {array} \right]
\left[ \begin {array} {ccc|r} 1 &amp; -1 &amp; 2 &amp; 1 \\ 0 &amp; 1 &amp; 0 &amp; 5/(k+1) \\ 0 &amp; 0 &amp; 1 &amp; 3 \end {array} \right]
\left[ \begin {array} {ccc|r} 1 &amp; -1 &amp; 0 &amp; -5 \\ 0 &amp; 1 &amp; 0 &amp; 5/(k+1) \\ 0 &amp; 0 &amp; 1 &amp; 3 \end {array} \right]
\left[ \begin {array} {ccc|r} 1 &amp; 0 &amp; 0 &amp; 5/(k+1) - 5 \\ 0 &amp; 1 &amp; 0 &amp; 5/(k+1) \\ 0 &amp; 0 &amp; 1 &amp; 3 \end {array} \right]
After all these steps, my final identity matrix looks like this:
\left[ \begin {array} {ccc|r} 1 &amp; 0 &amp; 0 &amp; -5k/(k+1) \\ 0 &amp; 1 &amp; 0 &amp; 5/(k+1) \\ 0 &amp; 0 &amp; 1 &amp; 3 \end {array} \right]
So now it looks like the possible values of k are all real numbers except -1 and 0. Is this correct?
Why could k not be 0? Isn't x= 0, y= 5, z= 3 an acceptable solution?
The matrix equation, Ax= b, will have a single solution as long as det(A) is not 0. Since there is only one k in the matrix, det(A)= 0 will be a linear equation in k. There should be only one value of k for which this system does not have a single solution.
You could have seen that back in your original reduction:
If the "pivot", k+ 1, is 0 then you cannot have a single solution.
Wow, how dumb of me... :redface: Of course k=0 is a solution! For some reason I was looking at it like 1=0. :confused: So it looks like the only value that won't work is -1, as I thought earlier. Thanks!
Hence, it's always necessary to create a 'discussion' before dividing with k+1, as in post #7, since, for k = -1 the term is undefined.
