Matrix Derivative Homework: Show Differentiability and Find Derivative
  • Thread starter Thread starter Gavins
    Derivative Matrix
Gavins
Let f: R^nxn -> R^nxn be the function f(A) = A^-1. ie f is the inverse function for some nxn matrix. Show it is differentiable and find the derivative.
I need to do something along the lines of (A + H)^-1 = A^-1 + f'(A)H + p(H) where p is a remainder term. I'm not sure how to expand this. I've looked in my notes and our lecturer did something along the lines of (A + H)^-1 - A^-1 = (A+H)^-1(I - (A+H)A^-1) = (A+H)^-1(-HA^-1). I can't really figure out what to do next since it doesn't seem easy to expand (A+H)^-1.
It might be easier to start with the relation f(A) A = I and differentiate both sides.
f'(A)A + f(A) = 0?
f'(A) = -A^-2
That's assuming the derivative exists. Check if the remainder term goes to 0 to show it is differentiable. Let |.| be the norm.
(A + H)^-1 - A^-1 + A^-2H = p(H)
|p(H)|/|H| = |(A + H)^-1 - A^-1 + A^-2H|/|H|
=< |(A+H)^-1|/|H| - |A^-1|/|H| + |A^-2|
I don't think this is right since this definitely doesn't go to zero when H goes to zero. Sorry for the really bad format.
You can write f'(A) in terms of f(A). Determine the existence of f'(A) in terms of the existence of f(A).
I'm not sure I understand. Is this easy to do from first principles? I think that's what my lecturer wants. Specifically, using the definition of the derivative, f(x+h) = f(x) + f'(x)h + p(h).
Thanks.
You might want to step back and ask "What is the nature of this beast?" regarding the derivative of the inverse of some matrix A with respect to A.
Hint: It is not an n×n matrix.Given some invertible matrix A and a small perturbation δ of this matrix, assume that (A+δ) is invertible. Without loss of generality you can express the inverse of (A+δ) in the form (A-1+ε). Derive an expression for this matrix ε.
Hint: Solve for (A-1+ε)(A+δ)=I, assuming that the term εδ is small.What does this tell you about the desired derivative? What assumptions did you make that need to be validated?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
