Matrix Multiplication -- Commutivity versus Associativity
12 replies · 2K views
Crystal037
If A is a square matrix, then A^2.A^3=A^3.A^2.
Is the above statement true or false????
A^2.A^3=A^3.A^2.
According to me matrix multiplication is not commutative. Therefore A^2.A^3=A^3.A^2 should be false. But at the same time matrix multiplication is associative so we can take whatever no. of A's we want to multiply i.e A^5=A.A^4 OR A^5=A^2.A^3
Matrix multiplication is not commutative which means AB is NOT NECESSARILY BA. That doesn't mean that they have to be unequal.
There are many cases where the matrices commute, such as this one. Another one is a matrix and its inverse. The definition of the inverse of ##A## is a matrix ##A^{-1}## such that ##A^{-1}A = A A^{-1} = I##. The product most definitely commutes, and in either order gives you the identity matrix.
Two additional trivial examples: the identity matrix, ##IA = AI = A## and the zero matrix ##0 A = A 0 = 0##.
I have tried for some matrices an even for general matric having elements a11,a12...
The result shows that the above statement is true
You cannot show a statement based on a couple of examples. The correct argumentation is using associativity as you outlined in the first post.
Sure, for the simple reason that both expressions are equal to ##A * A * A * A * A##, regardless of how ##A## is defined. And as you said, there's an associative property for matrices. So ##A^2 A^3 = A^3 A^2 = A A^4 = A A^3 A = \cdots##
By the way, remember that a scalar can be interpreted as a 1 x 1 matrix. And scalars definitely commute under multiplication. So ##ab = ba## is another example of "matrices" that commute under multiplication.
So to conclude any matrix A , A^n=A*A^(n-1)=A^2*A^(n-2)...=A^n-1*A.
But what about matrices which are non-invertible. Please explain through an example
Yes correct Also Is dividing a matrix A with B is same as multiplying A with additive inverse of B?
yeah Yeah sorry multiplicative inverse
So is the above statement true for multiplicative inverse or simply inverse
Yes. In fact, multiplying by the multiplicative inverse is the definition of division in groups generally.
