Matrix Transformation: U^\dagger vs U
Niles
Hi guys
Ok, let's say I have a matrix given by
<br /> M = \sum_{ij}M_{ij}a_i^\dagger a_j,<br />
and I wish to transform it. Now in some books I have read they write the transformation as
<br /> s = \sum_{j}U_{ij}a_j,<br />
while in some notes I have read they write it as
<br /> s = \sum_{j}U^\dagger_{ij}a_j.<br />
What is the deal here? What is the proper way of doing this? :confused:
Kind regards,
Niles.
Suppose you have a Hamiltonian which can be represented as a quadratic form between boson operators:
<br /> {\cal H} = \sum_{ij}a^\dagger_iH_{ij}a_j = \mathbf a^\dagger\mathsf H \mathbf a<br />
where the matrix H_{ij} is hermitian.
Suppose you find the eigenvectors of H_{ij} and put them as normalised columns in a matrix U_{ij}, which is unitary.
Then a natural way to rewrite the hamiltonian is:
<br /> {\cal H} = \mathbf a^\dagger\mathsf H \mathbf a =<br /> \mathbf a^\dagger \mathsf U\mathsf U^\dagger\mathsf H \mathsf U\mathsf U^\dagger\mathbf a = \mathbf b^\dagger \mathsf D \mathbf b<br />
where \mathsf D = \mathsf U^\dagger\mathsf H \mathsf U is diagonal, and the vector of boson operators is transformed as \mathbf b = U^\dagger\mathbf a.
Of course, I could equally well have said put the eigenvectors as normalised columns of the unitary matrix U^\dagger, and it would all be the other way round!
By the way, your first line is confusing: you have two matrices there. M acts on fock space as an operator (and is infinite dimensional for bosons), but M_ij is only as large as the number of sites.
Just to be absolutely clear: When you say "other way around", then you mean that we go from
<br /> \mathbf b = U^\dagger\mathbf a<br />
to
<br /> \mathbf b = U\mathbf a<br />
Yes, U is a unitary matrix, which implies that U^\dagger is also unitary. Whether you attach a dagger doesn't really matter, as long as you are consistent with the definitions you choose.
In the context of diagonalising hamiltonians like my example, the way I have written it is probably more conventional. In another situations, the other way might be more suitable.
Check out active/passive transformations, it might help.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
