Matrix with complex numbers, linear algebra
The discussion revolves around finding the value of α for which the given system of equations has a unique solution, emphasizing that this involves complex numbers. The determinant of the associated matrix must be non-zero for a unique solution to exist. If the determinant is zero, the conditions for consistency depend on the value of β, which must be determined for the system to have solutions. The participant expresses difficulty in applying matrix concepts to complex numbers, noting that the principles remain the same despite the complexity. The conversation highlights the importance of understanding determinants and echelon forms in solving such systems.
trobis
The system of equations:
ix - y + 2z = 7
2x + αz = 9
-x + 2y + 5iz = β
has a unique solution, except for one value of α. What is this α - value? If the matrix doesn't have a unique solution, then what value should β have for the matrix to be consistent and what is the solution then? (Parameters α, β and the unknowns x, y ,z are complex numbers)
I have tried to solve this as a matrix with the echelon form, but I can't get anywhere since I have never before done matrices with complex numbers.
Except for the "difficulty" of remembering that i2= -1, there is no difference. A matrix equation has a unique solution if and only if the determinant of the matrix is non-zero, which is the same as its echelon form having no zeros on the diagonal. If there is a 0 on the diagonal, there are no solutions if the other numbers in that row are non-zero, infinitely many if the other numbers are zero.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 18 ·
