Max Horizontal Force: Calculate with Cam Setup & Motor Torque
  • Thread starter Thread starter jeffc0987
    Cam
The discussion centers on calculating the maximum horizontal force produced by a cam setup on a pushrod, utilizing known motor torque and RPM values. The user reports achieving approximately 150 lb of force with 84 lb*in of torque, raising concerns about the accuracy of this measurement. The user questions whether the force in the X direction should be a fraction of the total torque based on the distance from the torque application point to the cam's contact point with the pushrod. An important clarification is made regarding the angle of rotation (phi), which should be measured from the torque application center.
  • Understanding of torque calculations in mechanical systems
  • Familiarity with cam mechanisms and their operational principles
  • Knowledge of force vectors and their components
  • Basic principles of rotational dynamics
  • Research torque-to-force conversion in cam systems
  • Study the effects of angle of rotation on force output
  • Explore frictional force considerations in mechanical setups
  • Learn about the dynamics of pushrod mechanisms in engineering applications
Mechanical engineers, robotics enthusiasts, and anyone involved in designing or analyzing cam-driven systems and pushrod mechanisms.
jeffc0987
I am having to figure out the maximum horizontal force our cam is able to produce on a pushrod that slides back and forth through bushings. I have attached a picture showing the basic setup.
The motor torque, and RPM's are known and for this estimate I am ignoring frictional forces.
I'm not sure if I'm making this out to be way more complicated than it should be, any help would be appreciated.
I'm still having trouble with this problem because testing shows this setup (picture attached) can produce up to ~150lb. of force using 84 lb*in of torque. This seems way too high--shouldn't it only be able to produce near that amount of force in the X direction when phi=90 and the entire force from the torque is directed that way?
I would have assumed the force in the X direction would be a fraction of the total torque based on the distance between the center and where the cam touches the pushrod.
Any thoughts?
[EDIT]
the angle of rotation phi should be off of the center of where the torque is applied, not the center of the cam.
  • · Replies 18 ·
31K
