Max Mass Supported by 5.6-Diameter Suction Cup
The maximum force a 5.6-diameter suction cup can support is calculated to be 250N, based on atmospheric pressure and the area of the cup. To determine the mass it can hold, the gravitational force must be considered, which is the weight of the mass supported by the cup. The coefficient of friction between the cup and the wall, which is 0.65, plays a crucial role in maintaining the cup's adhesion. The discussion suggests visualizing the cup in a horizontal position to better understand the forces acting on it. Ultimately, the calculation of mass supported requires integrating both the maximum force and the effects of friction.
savva
How massive an object can be supported by a 5.6 -diameter suction cup mounted on a vertical wall, if the coefficient of friction between cup and wall is 0.65? Assume normal atmospheric pressure.
I calculated the maximum force which I realized was when the pressure inside the suction =0
Therefore Fmax=pA=101.3*10^3(pi(0.028^2))= 250N.
I don't know how to find the how much mass can be supported by the suction cup. I tried a number of answers and they were all wrong.
If you hook up some mass m to the cup, what forces will be acting on the cup?
Turn the experiment 90 degrees in your mind so that the suction cup is resting horizontally atop the wall instead of vertically against it.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
