Max/min of multivariate function
Panphobia
max/min of
f(x,y) = x + y
constraint xy = 16
With lagrange multipliers I did
## \nabla f = (1,1) ##
## \nabla g = (y,x) ##
## \nabla f = \lambda \nabla g ##
## 1 = \lambda y ##
## 1 = \lambda x ##
Since y=0, x=0 aren't a part of xy = 16 I can isolate for lambda
## y = x ##
## y^2 = 16 ##
## y = \pm 4 ##
## y = 4, x = 4##
## y = -4, x = -4 ##
## f(4,4) = 8 ##
## f(-4,-4) = -8 ##
I got these values, but my answer key says that there are no minimums or maximums, can anyone explain why?
The values you have found are relative min/max points as you move along xy=16. But neither are absolute extrema because x+y gets larger and smaller than both then you let either x or y get large positive or negative.
Yea I understand since as x approaches infinity, y approaches 0, or x approach negative infintiy y approaches 0, so f(x,y) never has a max or min.
In the positive quadrant ##x, y \geq 0## your constrained ##f## does have a minimum, but no maximum. In the third quadrant ##x \leq 0, y \leq 0## the constrained function has a maximum, but no minimum. If we throw out the information about quadrants then, of course, it is true that the constrained ##f## had neither a maximum nor a minimum.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
