Maximizing Projectile Range on a Slope: Finding the Optimal Angle Alpha
  • Thread starter Thread starter FissionMan1
    Projectile Slope
7 replies · 9K views
FissionMan1
How do you find the maximum range a projectile will hit (shot at angle alpha) on a slope (angle theta) when theta is less than alpha. Also, what is the best angle for alpha. I would only like a head start, do not post the answer please.
We know that there are constants alpha, theta, and Vo.
I derived the equation for the distance (L) the projectile will travel up the slope.
L=(2Vo^2)/g*(cos(a)/cos(b))*(sin(a)-cos(a)tan(b))
My thoughts are that we make beta = 0 and alpha = 45, but I believe the professor is looking for an equation instead of an actual number so that I can prove it is the best angle.
Here we will have to develop a good relation.
Now the angle of the plane is theta and the angle of the projection is theta.
Now let the ground be represented by a line,AB. And the plane is AC
And the angle between AB and AC is alpha. Now you will have to use the following ideas.
[tex]1) cos\alpha\ = \frac{AB}{AC}[/tex]
2) The vertical displacement is zero wrt AC so now you can apply the equation of kinematics which covers time,initial velocity in y direction and g.
Now we can get time out of it.Now we know that the horizontal comp of velocity is constant and hence we can say that
[tex]AB = ucos\{\alpha\ + \theta\}T[/tex]
And now use 1 so you will get AB. Which is the range and now by using logic and trigonometry you can find the angle for which R is max.
I understand how to find R, but I'm not trying to find that. I am attempting to find the angle at which the projectile will land the farthest up the hill for a given Vo.
So when you get R. Try to find out that for which angle the R would be maximum.
R, according to your words, is the projectile's distance over a flat surface. I am trying to find the angle of maximum projection up a slope as a function of AC and theta.
Hold on. What are you trying to say.
I will have to break the forum rules as you are not understanding what i am trying to say.
The equation for AC is as follows
[tex]\frac{2u^2sin(\phi\ - \theta)cos\phi}{gcos^2\theta}[/tex]
where phi is alpha + theta. Now simplify it and you will get the following for AC
[tex]\frac{2u^2sin[(2\phi\ - \theta) - sin\theta]}{gcos^2\theta}[/tex]
To get maximum AC here
[tex]sin(2\phi\ - \theta) = 1[/tex]
Hence in that case max range would be
[tex]\frac{u^2}{g(1 + sin\theta)}[/tex]
All this equations, I have derived by the method i gave you in the last post.
And now from the above three equations you can find out the angle.If not i am always here.
