Maximum kinetic energy of a rocket in free space.
The discussion revolves around calculating the maximum kinetic energy of a rocket in free space as it emits mass at a constant rate. The initial approach involved using conservation of momentum and integrating to find the velocity and kinetic energy equations. Participants highlighted the importance of correctly substituting logarithmic expressions and suggested finding the maximum kinetic energy by expressing it as a function of mass for easier differentiation. The final result indicated that the maximum kinetic energy occurs when the mass of the rocket is a fraction of its initial mass, specifically at m = M/e^2. The conversation emphasizes the complexity of the calculations and the need for careful handling of logarithmic terms.
Pianodan
I'm returning to grad school for physics this fall, but I've been out of the classroom for thirteen years. (teaching music, of all things) I'm working my way through practice problems for the placement exam, but I don't have any way to verify correct answers for the problems unless I find something similar online. To be fair, I usually do. But this one, surprisingly, I can't find a direct analog for.
A rocket starts from rest in free space by emitting mass at a constant rate \alpha and with ejection velocity u relative to the rocket. At what fraction of the original rocket mass is the kinetic energy of the rocket a maximum. (Assume the mass of the empty rocket to be negligible)
Just kinetic energy and momentum, as far as I can tell. Forgive me, I'm not great with LaTex yet, so I'm trying to minimize typing it here.
Using conservation of momentum, reach the basic rocket equation:
M dv = u dm
where M is the inital mass of the rocket. Separate variables and integrate:
v(t) = u ln (M / m(t))
where m(t) is the mass of the rocket at time (t)
The Kinetic Energy, T(t), of the rocket is:
1/2 (m(t) ) v(t)^2
Substitute m(t) = M - \alphat and the value of v(t) from above to get:
T = M u^2 ln (M/m(t)) - \alpha t u^2 ln (M/m(t))
The kinetic energy should be at a maximum when the time derivative of the KE is zero, so differentiate (and this is the most likely place I screwed up) the above equation with respect to time to get:
\frac{dT}{dt}=ln(\frac{M}{m(t)})
Setting that equal to zero, you find only one extremum in T at m(t) = M, or at the point of total fuel consumption. Given that the KE of a massless rocket is zero, I'm at a loss.
Just thinking about this in the abstract, it seems that the velocity over the entire period of thrust, the mass should decrease, and the KE, as the product of the mass and the square of the velocity (and 1/2), should increase to a maximum and then decrease to zero as all the mass moves to the ejecta.
What am I missing here?
I think that one of the mistakes you made is when you substitute the expression for v(t):
you should have (ln (m/M))^2 instead of ln(m^2/M^2)=2ln(m/M)
Welcome to PF!
You may also want to find maximum kinetic energy using kinetic energy expressed as function of mass, Tm, since dTm/dm = 0 is a bit easier to solve by hand than dTt/dt = 0. Once you have a mass for maximum T you can easily insert that in your mass-time equation to find the corresponding time.
Thanks to both of you for the help. It's clear that my facility with logarithms has eroded greatly. After making the correct substitution into the time differential, I discovered that it was indeed just as nasty as Filip had suggested. The mass differential was simpler, but still a bit of a chain rule slog.
T = 1/2 m(t) v^2 = 1/2 m(t) u (ln (M/m(t)) )^2
dT/dm = 1/2 u [ ln^2(M/m) - 2 ln (M/m) ]
Setting this equal to 0 yields the relatively simple looking:
ln(z)^2 = - ln^2(z) where z = (M/m(t))
Plugged it into Alpha and got a solution right away, but it took me a good half an hour of head scratching to understand it. I just about kicked myself when I got it - but that's always the way, isn't it? I hope my speed increases with practice - this was one of twelve questions on a three hour test.
Here's the final answer.
ln^2(z) + ln(z) + ln(z) = 0
ln(z)(ln(z) + 2) = 0
So there are two extrema - one at z = 1, and the other at z = e^-2
Looking at this, I think I lost a sign somewhere, since it implies that m / M at max KE is greater than one (e^2).
I concur with your 2nd equation, but from that you should get
ln2(z) - 2 ln(z) = ln(z) (ln(z)-2) = 0
which implies that z = e2 and thus m = M/e2 is a solution for dT/dm = 0. I guess you are correct about loosing a sign along the way :smile:.
Oh... right. (bangs head on desk)
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
