Where are the maximum stresses located in a thin plate with opposing forces?
  • Thread starter Thread starter ladil
    Maximum Plate
To calculate the maximum stress in the thin plate under opposing forces, one must first establish the equilibrium of forces and moments, as the current configuration suggests it is not in static equilibrium. The force applied to the left can be ignored, focusing instead on the axial tensile load and the bending moment, which increases towards the wall. The equilibrium equations for horizontal and vertical forces, as well as moments, should be solved to determine the reaction forces. The normal stress can then be calculated using the formula σ_{11}=F/A-My/I, where y is the distance from the neutral axis and I is the second moment of area. Proper application of these principles will lead to the identification of maximum stress locations in the plate.
ladil
Hello,
I need some help (or a lot) of calculating where and how much the maximum stress is in a plate as seen in my attached figure.
It´s a thin plate (1mm) that is designed as my picture and it has two forces acting in opposite direction.
How do I calculate where the maximum stresses in the plate would be?
Thank you. Any other dimensions are arbitrary.
An immediate challenge to solving this is that, if the loads are correct, the object is not in static equilibrium. It will start rotating clockwise. So either the position is correct and the loads are incomplete, or one needs to find the equilibrium position.
I´m sorry.
The Force applied to the left in the figure can be neglected.
It should be completely constrained in that position.
So you'll have an axial tensile load of magnitude F, along with a bending moment that increases as the lever arm from F increases, reaching its maximum at the wall. Know what I mean?
I understand a little bit.
Should I do a equlibrium equation?
F-R=0 in the horisontal direction? R being reaction force on the wall.
I need some more assistance before I can go on.
Thank you.
Exactly; solve the equilibrium equations for horizontal and vertical forces and for moments. At any point, then, you can find the normal stress from \sigma_{11}=F/A-My/I, where y is the distance from the neutral axis and I is the second moment of area. This equation is derived in any Mechanical of Materials textbook.
Thank you.
