Maximum tension a cable can withstand.
The maximum tension a cable can withstand is 9000N, and the upward acceleration of the elevator is 1.00 m/s². To determine how many 80kg passengers can be safely carried, the mass of the elevator, which is 520 kg, must be considered. The forces acting on the system include the weight of the elevator and the tension in the cable. By analyzing these forces, it becomes clear that the calculation must account for both the weight of the elevator and the additional weight of the passengers to ensure safety.
cdx
If the maximum tension that a cable can safely withstand is 9000N and the maximum upward acceleration of the elevator is 1.00 ms2, how many 80kg passengers may be safely carried in the elevator?
(The mass of the cable is negligible)
F=ma
T=mg
If I let ay=1.00 ms2 and F=9000N then I have:
9000N = m * ay and m = 9000. The number of 80kg people the elevator can withstand is 9000 / 80 = 112 people.
Is this correct?
No. You first need to know the mass of the elevator. Is it given? Then note that weight and mass are not the same, and that net force = ma. You need to identify all the forces acting on the elevator/people system. Hint: don't forget the weight acting down.
The mass of the elevator is 520 kg. Sorry I forgot to include this. Correct me here: There are two forces acting on the elevator, FG and FN.
FG = mg = 520 kg * (-10) = -5200N.
Help?
Help?
I think the 2 forces you want to analyze in the Y direction are Fw and Ft, which oppose each other. Fw is acting in the negative Y direction and Ft is acting in the positive Y direction. Ft of course being the force of tension
So id look at it as the max force of tension it can hold is 9000N=Ft,
Ft-Fw=ma ----> Ft=ma+(Fw)
