Norman Albers
- 21
- 0
I am trying to develope magnetic terms in the Minkowski field tensor, based on an electron model positing circular currents and thus A_{\phi}. It is easy enough to decompose this into A_{x,y} and construct the tensor in a Cartesian basis, but essentially my study requires spherical coordinates because my goal is not just to reproduct Maxwell's equations, but to put this magnetic field into the Reissner-Nordstrom solution in spheric coordinates. No reference I've yet found deals with this: the circular vector potential manifests B_r and B_\theta. I need to be sure of the three expressions of the Minkowski form since you need covariant, contravariant, and mixed to build up the RHS of the Einstein equations, the stress-energy tensor. I have already accomplished this with the inhomogeneous electric field, which though not a point source, worked through the usual radial field solution without such difficulty. This problem is represented with only an E_r so nothing usually is shown about the magnetic off-diagonal terms needed here. It is not so hard to effect a rotation of the orthogonal vector basis, as per spheric coordinates, but the formalism is not easy through the rest of this problem. The spheric coord. transform is like a rotation and a scale matrix with diagonal elements of <1,r,rsin\theta>. This is like the square root of the metric g_{ab} usually spoken of. . . . . . . .Part of this issue revolves around getting the expressions for CURL straight, in the spheric coords.
