Answering MCQs on Sound Amplitude and Intensity
The discussion revolves around two multiple-choice questions (MCQs) related to sound amplitude and intensity. For the first question, the rapid compression and expansion of sound waves indicate a high frequency, which corresponds to a high pitch, making option (b) the correct answer. The second question compares waveforms of soft and loud sounds, with the consensus that the loud sound will exhibit a greater intensity change, as intensity is directly related to amplitude. Participants clarify that while frequency, pressure, and energy changes are interrelated, intensity is the most definitive factor in this context. The conversation emphasizes understanding the distinctions between these sound properties for accurate answers.
UNknown 2010
Hi All,
I have two MCQ, I could not answer them.
All choices seem to be close to each others.
I would be so grateful if you could help me.
When the compression and expansion is very rapid, the sound is said to be high in:
a) amplitude
b) pitch
c) frequency
d) loudness
e) intensity
Pitch = Frequency so it can't be neither (C) nor (D) as I think
Amplitude related to intensity so it can't be neither (A) nor (E)
intensity = power/area = energy/time.area
energy is directly propotional to the square of change in amplitude
so it can't be (e) !
Could you show me the answer with clarification please ??
another MCQ
If one ertr to compare the wave form of a soft sound with the wave form of a much louder sound. The loud sound will have a greater ------------
a) frequency change
b) intensity change
c) pressure change
d) energy change
e) sound quality
Sure, it is not (e)
and (a), (b), (c), (d) are all interrelated !
OK
You are getting confused here, I think
1. If the compression and expansion are rapid, that means that the time it takes to complete a cycle of compression and expansion is small, yes?
Now, I'm sure you understand that frequency is inversely proportional to period, so the frequency must be high.
However, the question does not ask you the properties of the wave itself - it is asking about what the wave sounds like. If you have a high frequency, you have a high pitch. Answer *should* be (b)
2. You are right when you say that they are related. However, everything other than intensity depends on a lot of factors other than the loudness! The only thing that can be certainly deduced from the question is that the sound will have a larger amplitude, that is to say, a larger intensity. I mean, the two sounds can both be at the same frequency, since frequency is defined not by loudness, but by the period of the wave!
Thanks for your fast reply.
2. so it's false MCQ ?!
No, its just that ONLY the intensity change is related to just the difference in waveforms
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
