Measure distance of devices via radio?
  • Thread starter Thread starter ghubben
    Measure Radio
Measuring distance between two devices using radio signals with millimeter precision over a distance of 15 meters is highly challenging due to the speed of radio waves, which travel at 300,000,000 meters per second. Common circuits operate at the nanosecond level, making such accuracy difficult to achieve. Alternatives like ultrasonic sensors can detect proximity changes but typically do not reach millimeter precision; they usually detect objects down to about 2 cm. A potential solution involves using a combination of radio signals and ultrasonic pulses, where the radio signal triggers the ultrasonic measurement, allowing for more accurate readings. Overall, achieving the desired precision requires advanced technology and expertise.
ghubben
Hello,
I've got a question about distance measuring via radio.
I would like to measure the distance between two devices, relatively small ones, using radio and my question is how fine that measurement can be? The devices would be a maximum of say 15 metres apart and a preciseness of about a millimeter is needed. Is that possible with common circuits available?
I'm not an electrical engineer of any sort so please keep it in laymans terms.
Thanks!
//Fredrik
I don't think you could expect that sort of accuracy from radio signals.
The problem is that radio signals travel VERY FAST.
The speed of light and radio waves is 300 000 000 meters a second.
So, that is 300 meters a microsecond and 0.3 meters or 300 mm per nanosecond.
And the best logic circuits we have are capable of operating at the nanosecond level.
Even then it would be a very difficult project.
There might be a low tech solution using a video camera above both objects, but the answer to your question is no, unfortunately.
Ultrasonics may be another way. A sound wave travels at about 340 meters a second.
That is about 0.34 millimeters per microsecond.
So, you could send out a radio signal that a sound pulse was on its way and then count the time until the sound pulse got to the second object.
The radio signal would take a negligible time to get there, so quite an accurate reading could be obtained.
Developing something like that would take time and expertise though.
Hi Fredrik,
Sorry, i am not the expert you looking for but just happen to see your posting and like to share some info with you.
What i know is that ultrasonic promixity sensors used by cars and robots can detect objects upto as near as 2cm, as shown in this webpage :
http://www.parallax.com/Store/Sensors/ObjectDetection/tabid/176/ProductID/92/List/1/Default.aspx?SortField=ProductName,ProductName
Unfortunately, i do not know how can it detect proximity changes as small a millimeter. Personally, i do not think it can as car sensors are not that sensitive, i suspect.
Lasers night be a possibility. The resolution of radar is limited to the wavelength of the signal.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
