The placement of static pressure probes for measuring fan performance curves should be determined by the specific application requirements. Probes can be positioned near the surface or at the center of the duct, depending on the desired measurement conditions. The key parameter to focus on is the volume of air shifted per second rather than the speed of airflow in meters per second. Turbulence within the duct can influence the dynamics of static pressure readings, particularly for probes positioned perpendicular to the airflow. Accurate placement and consideration of these factors are crucial for effective fan performance analysis.
#1
Yuri B.
137
For finding fan performance curve where better to put static pressure probes - near the surface or near the center of the duct ?
I think it would depend upon the application that you want the fan for. You would need to specify your own measurement conditions to suit what you want to use it for. Is the relevant parameter the volume shifted per second or the speed of the air flow in m/s?
#3
Yuri B.
137
Volume. Should turbulence in some points of the duct add some dynamics to static pressure being measured by the probe placed right perpendicular to flow ?
Do we even know? My understanding of dark energy is that particles come into existence, exert and outward force, then vanish. My problem with that is how, of course, then how does dark energy know to push everything in the same direction? The pressure exerted would be in all directions, even if the space was moving so why isn't stuff pushed all over the sky?
Thanks - rev
I think it's easist first to watch a short vidio clip
I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way?
The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
