Measuring Pressure in Lab: Add Atmospheric?
The discussion revolves around whether atmospheric pressure should be added to pressure readings taken from gauges in laboratory fluid systems, particularly in the context of the Rankine cycle. Participants explore the implications of using gauge pressure versus absolute pressure in various applications.
  • Some participants suggest that if the application requires knowing the absolute pressure, such as in the ideal gas law, atmospheric pressure should be added to the gauge reading.
  • Others argue that for determining rupture pressure or similar scenarios, only gauge pressure is necessary since atmospheric pressure acts as a counter pressure.
  • It is noted that the type of gauge used is crucial; differential pressure gauges require atmospheric pressure to be added, while absolute pressure gauges do not.
  • One participant inquires about using gauge pressure to obtain enthalpy from tables in the context of the Rankine cycle, questioning if gauge pressure alone is sufficient.
  • Concerns are raised regarding the precision needed for pressure measurements in the Rankine cycle, particularly whether an average atmospheric pressure value suffices or if real-time accuracy is required.
  • Another participant emphasizes the importance of knowing the reference point of the gauge transducers being used, especially in tuning a Rankine cycle plant.
Participants express differing views on the necessity of adding atmospheric pressure to gauge readings, indicating that multiple competing perspectives remain unresolved. There is no consensus on the best approach for using pressure readings in the context of the Rankine cycle.
Participants mention the need for clarity on the type of pressure transducers being used, as well as the implications of using gauge versus absolute pressure in specific applications. There is uncertainty regarding the precision required for measurements in the Rankine cycle.
y2j
When we take pressure readings by pressure gauge (Bourbon pressure gauge or pressure transducer) in the laboratory for any fluid system ,in this case, is the atmospheric pressure value (1 bar) must be added to this readings when we use them in any calculations later or them must be used alone without adding atmospheric pressure value
Thanks to everyone who takes a look at the subject
If you application involve working with or knowing the absolute amount of gas in a vessel then you must add the current atmospheric pressure to the reading for example in using the ideal gas law. However if you are interested in say the rupture pressure of a vessel then you only use the gauge pressure since the atmosphere is providing a counter pressure from the outside. so you only need in the pressure above atmospheric This would also apply to fluids except if the vessel is in a vacuum (outer space) in which case you need to add one atmosphere to the reading.
It depends on what type of gauge you have. Some gauges measure differential pressure (and atmospheric pressure must be added) while others measure absolute pressure (so they already account for the atmospheric pressure).
thanks for reply
I am working on Rankine cycle
and in some component there is a liquid and in the other there is a vapor then,
when I want to obtain enthalpy from tables at these pressure (in addition to temperature ) ,can I use only gauge pressure?
If you have a vessel with a gaseous and a liquid phase and you need to consider the total amount of gas, what do you think?
I am using pressure transducer with 4-20 mA signal output to measure the pressure in specified point and not measure differential pressure
That's not really helpful in terms of determining whether the transducer is differential or absolute. Do you know its manufacturer and model number? Just look that up and take a peek in the manual to make sure (or on the specifications page online).
Thanks
I will try
y2j said:
thanks for reply
I did the exact same thing in an internship. Think about the precision you need. Will an average local atmospheric pressure value work? Or does it need to be more accurate and in real time?
Compare the price tag and range of absolute vs gauge transducers.
Tuning a small rankine cycle plant (organic, i assume?) is hard. Not knowing what your gauge transducers are referencing to would make it a lot harder.
Exactly , I am working on small organic rankine cycle, But I did not understand exactly what you mean .
Manufacturer of these pressure transducers tell me that are relative pressure transmitter and not absolute .
What exactly don't you understand?
Have you done a course in basic fluid mechanics?
  • · Replies 26 ·
  • · Replies 45 ·
