Is the Parallax Method Still the Most Widely Used for Measuring Star Distances?
  • Thread starter Thread starter neoweb
    Measuring Stars
The parallax method remains the primary technique for measuring distances to relatively nearby stars, involving two measurements taken six months apart as Earth orbits the Sun. This method relies on geometric principles and has been enhanced by satellite missions like Hipparcos, which provided highly accurate parallax measurements. The distance from Earth to the Sun was historically estimated using parallax during lunar eclipses, with further refinements made through Newtonian physics and radar astronomy. While parallax is effective for stars within a few dozen light-years, astronomers utilize other methods, such as Cepheid variables and supernovae, for measuring greater distances. Overall, parallax continues to be a vital tool in astrophysics, complemented by advanced techniques for more distant celestial objects.
neoweb
Is the parallax method still the one most widely used (for the relatively nearer stars at least)? More particularly, is it still the case that we take one measurement then wait six months until the Earth is on the other side of the sun and take a second measurement? Or has this been superseded by something else?
Also, with the parallax method we need to know the distance from Earth to Sun - so how did we first figure out how far away the Sun is?
Thanks in advance.
Astronomy news on Phys.org
If you measure the position of the stars you will note that they have an apparent displacement which is greatest when the Earth is moving at a right angle to the light arriving from the star. This displacement is caused by the aberration of light and its angle depends on the Earth's orbital velocity. Measuring this displacement allows us to determine the Earth's orbital velocity. given the length of the year and the orbital velocity, we can calculate the circumference of the Earth's orbit, and dividing this by 2 pi gives us the mean radius or distance from Sun to Earth.
The Earth to sun distance was first estimated by a dude named Aristarchus about 2300 years ago. Parallax was the first method used to gage the distance to other stars. It is arguably the most reliable since it relies on well known and accepted geometrical principles. It is still useful today. Other more sophisticated methods came into use more recently. The first method to emerge after parallax was the Cepheid yardstick. See here for more information.
http://curious.astro.cornell.edu/question.php?number=400
http://curious.astro.cornell.edu/question.php?number=128
Yes. http://astro.estec.esa.nl/Hipparcos/ has given us probably the most accurate distances to nearby stars to date. The principles on which it worked (the satellite has long since burned up) are a little arcane, but at the core is parallax.
The 'first' methods of determining the distance to the Sun were also parallax, but in an interesting way - a Greek astronomer (Aristarchus?) estimated the distance to the Sun by the shadow of the Earth on the Moon, during a lunar eclipse! (It's simple geometry). However, as several of his input parameters were wrong, he got the distance to the Sun wrong too.
More generally, since the Moon and Sun have the same angular diameter (as evidenced by solar eclipses), some simple geometry shows that once you have one distance (e.g. Earth to Moon), you can get the other. It gets a bit more complicated if you want to get accurate (e.g. orbits aren't perfect circles).
With Newton and accurate orbits of the planets and asteroids, the distance to the Sun was fairly accurately determined; however, only when radar astronomy was able to get an echo (from Eros, IIRC, though it might have been Venus) could the solar system distance scale be nailed down to ~km (or maybe more accurately). Today we have transponders on interplanetary probes, and the 'light return time' gives very accurate distances (we also need good ephemerises). Anyway, the distance to the Sun need not be all accurately known to work out distances to nearby stars ... the parallax angle (pre-Hipparcos) could only be measured to ~1 decimal place!
From what I understand...
Parallax is still used to give very good measurements for anything in the range of nearby stars (dozens of light years away). After that, distance measurements to stars in the galaxy become more uncertain and are often cross-referenced to various observations/calculations methods in order to reach a satisfactory answer (e.g., comparisons to other stellar distance measurements). Then Cepheid variables begin to help us out as a "standard candle" that can help improve measurements out to the nearby galaxies. After that, astronomers use supernova 1a as the next standard candle to get pretty good measurements of the more distant galaxies (perhaps +/- 10%?). Couple that with redshift measurements.
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons. Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
