How High Does the Child Become Airborne on a Slide?
The discussion focuses on calculating the height at which a child becomes airborne on a poorly designed playground slide. The slide consists of a straight section and a circular arc, with the child starting at a height of 9 meters and the arc having a radius of 7.2 meters. Participants suggest using conservation of energy to determine the child's speed at the circular arc and applying the formula F=mv²/r to find the necessary centripetal force. The normal force becomes zero at the point of losing contact, indicating the child becomes airborne. Overall, the solution requires integrating principles of energy conservation and Newton's laws to find the height of the child when they leave the slide.
hsbc2003
Just need some direction on the problem.
1. Homework Statement
A poorly designed playground slide begins with a straight section and ends with a circular arc. A child starts at point P and slides down both sections of the slide. At some point on the circular arc, the normal force goes to zero and the child loses contact with the ramp. Assuming the forces of friction are negligible, at what height from the ground will the child become airborne.
(( picture in the attachment))
the height from point p to the ground is 9 m. The radius of the arc is 7.2 m.
w=kf-ki+uf-ui; ki=0, ui=mg(9)
well, i figure out the speed in which the particle will be when it hits the circular arc, where uf=mg(7.2). Now how do i figure out how high it will be from the ground when the child will become airborne? I think I need to use F=mv^2/r somewhere in the equation to figure out the force needed for the particle to stay in the circular path and not go flying off. But after that, I'm kind of lost.
Thanks for the help.
Good. What provides the centripetal force? You'll need Newton's 2nd law and conservation of energy to solve this one.
HI hsbc2003! :smile:
Use conservation of energy to find the speed, v, at angle θ.
Then use mv²/r to find the normal force. :smile:
