Mechanics 3 Elastic Springs and Strings Problems
A user is seeking help with a Mechanics 3 problem involving a ball attached to a cord, where a horizontal force causes the cord to stretch and incline. The discussion clarifies that a horizontal force acts parallel to the ground, and emphasizes the need to analyze the vertical and horizontal components of the forces for equilibrium. Participants explain that the problem requires calculating the modulus of elasticity of the cord, not the spring constant, and that the tension in the cord is a key factor. The user expresses confusion about the number of variables and the definition of tension, which is clarified by other forum members. Overall, the conversation focuses on solving the mechanics problem through understanding force components and equilibrium conditions.
garyljc
Hello everyone ,
I'm new in this forum . I'm 16 and currently doing self study in Mechanics 3 . I've encounter a problem in the 2nd chapter of Mechanics 3 which is Elastic Springs and Strings . Here goes :
A ball of mass 0.5kg is attached to one end of a cord of unstretched length 0.6m whose other end is fixed. When a horizontal force magnitude Q N is applied to the ball holding the ball in equilibrium, the cord increase in length by 10% and is inclined at an angle of arcsin 3/5 to the downwards vertical. Calculate the value of Q and the modulus of the cord.
A few things that kept me wondering is that what do they mean by horizontal ? Does it means it acts along the slope or acts parellel to the ground ? Please help me , thank you = ):-p
garyljc said:
Hello everyone ,
Hi there garyljc and welcome to PF,
A horizontal force will act parallel to the ground. To answer this question, you will need to find the components of the force exerted by the chord, take vertical (y) and horizontal (x) components. Now, as the ball is in equilibrium what can we say about the forces acting on the ball? Next you will need to identify the forces acting on the ball. You should then be able to formulate to expressions, one vertically and one horizontally, which you may solve simultaneously. I am assuming here that the chord is thin, since we have not been given a diameter. (A diagram may be helpful in answering this question)
If the ball is in equilibrium , sum of the forces wil be equal to zero =) Got it . But I've found 2 equations ( Vertical and Horizontal ) , when I have 3 variables , which is Q , modulus of elasticity , R (normal reaction) . Is there anything I'm missing out ? What does the vertical equal to ? Thanks anyway
sup garlyci...force exerted by spring is (spring constant)*lenght displaced.
i can solve you the problem...butcan you please tell me what arcsine means beacasue in my country, we only have angles in terms of radians and degress...if you would convert it into degress...it would be a great help in my calculation.
thank you!
arcsin 3/5 means sin @ = 3/5
This is the wrong formulae to use. We are dealing with chords here, not springs. We are required to calculate young's modulus for the chord not the spring constant.
You should have only two unknowns is each equation (Q and a component of the tension). In this situation there are only three forces acting, (1)Q, (2)The tension and (3)The weight of the ball. There should be no reaction force.
But what will R be equal to ? There must be a normal reaction the particle
HINT: Look up the definition of tension
Tension is a reaction force applied by a stretched string (rope or a similar object) on the objects which stretch it. The direction of the force of tension is parallel to the string, towards the [centre of the] string.
Ahhhh , I got it , thanks anyway . Kinda hard though for me doing self study =) Cheers Hoot =)
No problem :smile:
