roam
- 1,265
- 12
The following is a solved problem:
http://img600.imageshack.us/img600/6503/questiono.jpg
I can't understand how they worked out these two components.
\vec{a}(t) = \frac{dv}{dt}\vec{T} + v \frac{d \vec{T}}{dt}
Where
\vec{T}(t) = \frac{d \vec{r}(t)/dt}{||d \vec{r}(t)/dt||} = \frac{\vec{v}(t)}{v(t)}
In the equation I posted above, I believe the first term is the tangential component of acceleration and the second one is the normal component. I want first to find the tangential component:
\vec{v}(t) = d(t^2 \vec{i} + 3t+2 \vec{j})/dt = 2t+3
|| \vec{v}(t) || = \sqrt{4t^2+9}
So substituting in
\frac{dv}{dt}\vec{T} = \frac{d (\vec{r}(t)/dt)}{dt} . \frac{d \vec{r}(t)}{dt}.\frac{1}{||\vec{r}(t)||}
2.(2t+3).\frac{1}{\sqrt{4t^2+9}}
= \frac{4t+6}{\sqrt{4t^2+9}}
But this is wrong. The correct answer must be
\frac{4t}{\sqrt{4t^2+9}}
What did I do wrong?
