Mechanics of Materials — Torsional Stress on a Spinning Shaft
The discussion revolves around the concept of torsional stress in a freely spinning shaft, particularly in the context of power transmission and the application of torsional formulas. Participants explore the relationship between shear stress, torque, and angular velocity in mechanical systems.
  • One participant expresses confusion about applying the torsional formula to determine the minimum shaft diameter when there appears to be no torsional stress due to the absence of fixed supports.
  • Another participant suggests that the power from the motor allows for the computation of belt tension, which is not zero, challenging the assumption of zero shear stress from the belt tension.
  • A different participant questions how the belt tension translates to torsional shear, noting that the shaft is allowed to spin without resistance to twisting.
  • One participant argues that the problem's nature is similar to earlier examples where moments are in opposition, highlighting the dynamic and static situations involved in the torque calculations.
  • Another participant acknowledges the resistance from the load attached to the belt, indicating a misunderstanding of the dynamics involved in the spinning shaft scenario.
  • There is a discussion about the relationship between power, torque, and angular velocity, with one participant attempting to clarify how these quantities interact under varying loads.
  • A participant notes that there is a tension drop across the pulley, which relates to the torque applied to the shaft, further complicating the understanding of the system.
Participants express differing views on the application of torsional stress concepts to the problem, with some asserting that there is no torsional stress while others argue that moments and tensions still play a role in the dynamics of the system. The discussion remains unresolved regarding the interpretation of shear stress and its relation to torsional stress in this context.
Participants highlight potential limitations in understanding the dynamics of the system, including assumptions about the nature of shear stress and the role of belt tension in relation to torque and angular velocity. The complexity of the interactions between these factors is acknowledged but not fully resolved.
mhrob24
Summary:: Torsional stress on freely spinning shaft?
Hey guys,
I’m having some confusion with a certain section of the “Torsion” chapter in my mechanics of materials book: “power transmission”.
Please see the problem below. This is very easy to SOLVE (basically plug and chug with the equations), but conceptually, I am not understanding something:
I do not see how we are allowed to use the torsional formula to solve for the minimum shaft DIA when from what I see, there is no TORSIONAL stress. The problems that were explained earlier in the chapter made sense because they were FIXED at one end. So the support fights the rotation, and because of this, the polar moment of inertia due to the shaft geometry is fighting torsional deformation. Without the support, the way I see it currently, the polar moment of inertia isn’t really “fighting” anything…right?
Like, when I look at this: all I see stress-wise is a shear stress due to reaction forces from the “supports” (the motor attachment point and the bearing support) that prevent translation of the shaft, and the shear stress from the tension force of that belt (but it’s not given, so it’s assumed zero). I know it doesn’t say to solve for torsional stress, but we’re using the torsional stress formula to solve it.
Idk where I’m going wrong here, but I’m spending too much time thinking about this now….
Thanks for the response.
I’m not really seeing how that’s possible. The 5 HP is the power from the motor. The belt isn’t spinning the shaft.
And even so, like I said, I do see that there is a shear stress developed in the shaft due to the belt tension, but how is that torsional shear? The shaft is allowed to spin. There isn’t a resistance to the twisting
The nature of this problem is the same as of the problems that were explained earlier in the chapter that were fixed at one end (zero angular velocity ω): two moments are fighting each other; one is a dynamic situation (ω > 0) and the other one is a static one (ω = 0).
The motor induces a driving moment and the rotating thing at the other end of the belt loop induces a resisting moment while it rotates.
The size of the belt is selected based on the calculation of its tension while normally rotating; therefore, there is certain amount of tangential force, which induces certain amount of moment or torque on the shaft when combined with the radius of the belt middle line.
Same principle would apply if the transmision of power were done via roller chain or gears.
Hey, nice to hear from you again.
This does make a lot of sense. I guess because it’s moving I felt like it wasn’t fighting anything, but like you said: there is still a resistance from whatever is attached to that belt; regardless of if it’s moving or not. Not sure why I didn’t see that…..
So just be sure I’m correctly thinking about how these equations work: power (mechanical) is work per second…..or in other words, torque times angular velocity. So solving for torque, you get power divided by angular velocity. So as the weight of whatever is being pulled goes up, the angular velocity would drop (there would be less cycles per second) which would mean torque is proportionally increased. So basically, the power supplied from the motor is constant unless angular velocity or torque is zero. This seems odd to me for some reason.
The belt tension coming into the pulley is different from that coming out of the pulley. So there is a tension drop across the pulley. This tension drop times the pulley radius is equal to the torque the load applies to the pulley and the pulley, in turn, applies to the shaft.
