Mechanics Projectiles Trajectory Question Help Needed
An anti-aircraft gun fires shells at a pilotless aircraft flying at a constant height of 3500m and speed of 100m/s. The task is to derive the equation x^2tan^2(theta) - (32000)xtan(theta) + (x^2 + 1.12x10^8) = 0 using the trajectory equation. The correct trajectory equation should be y = xtan(theta) - 0.5gx^2/(V^2cos^2(theta)). Substituting the known values for height and velocity allows for the elimination of cos(theta) to derive the desired equation. Proper application of these principles will lead to the solution.
ishterz
An anti aircraft gun with initial velocity 400m/s at angel theta above the horizontal, and the shells may be assumed to move freely under gravity. The target is a pilotless aircraft which flies at a speed of 100m/s directly towards the gun at a constant height of 3500m. A shell fired from the gun hits the aircraft when it is at a horizontal distance of 'x' m from the gun.
By using equation of trajectory show
x^2tan^2(theta)- (32000)xtan(theta) + (x^2 + 1.12x10^8) = 0
Equation of trajectory: y = xtan(theta) - gx^2/ (V^2 cos^2 (theta))
I assumed the y distance for both will be the same on collision, since the aircraft's height is constant
For the shell, I did :
x = 400cos(theta) t
therefore t= x/400cos(theta)
v= 400sin(theta)t - 5t^2
I subsituted for t in the second equation and tried to solve but could not get the answer.
Please help!
Thank you for your time
What is the question?
ehild
How to show the above equation of x^2tan^2(theta)- (32000)xtan(theta) + (x^2 + 1.12x10^8) = 0
What you did is the derivation of the equation of the trajectory, and your procedure is correct, if you meant y=400 sin(theta)-5t^2. But the equation you showed for the trajectory was not correct. It should be
y = xtan(theta) -0.5 gx^2/ (V^2 cos^2 (theta)).
You are also right using y=3500 m and V=400 m/s. Just plug in them to get the equation between theta and x, and use the identity
cos^2(theta)=1/(1+tan^2(theta)
to eliminate cos theta from the equation.
ehild
Ahhh
Thank you!
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
