Meissner Effect- magnetic focusing
Superconductors can indeed be utilized to focus magnetic fields, often referred to as "flux focusers," though typically in the form of thin films rather than cylinders. The proposed design of using a superconducting cylinder with a wire coil may not be efficient for applications like Gauss guns, which typically rely on a series of electromagnets to accelerate a projectile. The idea of extending the coil's magnetic field over a larger distance with a hollow cylinder aims to simplify the operation by eliminating the need for precise timing in switching coils. However, the effectiveness of this approach remains uncertain. Overall, while superconductors have potential in magnetic field manipulation, the specific design proposed may not enhance efficiency as intended.
Savant13
Could superconductors be used to focus a magnetic field? For instance, let's say we have a superconducting cylinder and we place a wire coil in one end. If we put current through the wire, could it be used as a more effective Gauss gun than the same coil without the superconducting cylinder?
Well, you can (and people do) use superconductors as "flux focusers", although that term usually refers to a thin superconducting film, not a cylinder.
However, I don't think the design you are proposing would be very efficient; AFAK Gauss guns are usually designed to us a ROW of electromagnets that gradually accelerate the slug; I can't see how a flux focuser would help.
It would be a hollow cylinder. My idea was to use cylinder to extend the coil's magnetic field over a large distance in one direction. That way you wouldn't have to deal with the hassle of switching the coils on and off at the right times.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
