Merry-Go-Round physics homework
The discussion revolves around a physics homework problem involving a merry-go-round with a specified radius and mass, which is initially set in motion with constant angular acceleration. The first part requires calculating the final rotational kinetic energy, which was found to be approximately 987 J. In the second part, when five children step onto the merry-go-round, the angular velocity decreases, and the initial poster initially miscalculated this value. The conversation highlights the importance of conservation of angular momentum over kinetic energy, noting that while angular momentum remains constant, kinetic energy is not conserved due to external forces acting on the system. The correct approach to solving the problem was confirmed through the application of these principles.
bpw91284
A merry-go-round in a playground has a radius of about 2 m and a mass of about 400 kg. Starting from rest, a parent begins to rotate it with constant angular acceleration. After 5 s, it reaches its final angular velocity of about pi/2 rad/s, and continues to rotate at that angular velocity
a.
Treat the merry-go-round as a uniform disk (the moment of inertia of a uniform disk is mr2/2); the final rotational kinetic energy of the merry-go-round is about ___ J.
b.
5 children, each with a mass of about 20 kg, step on the merry-go-round and stay near its edge. As they step on it, its angular velocity drops to about ____ rad/s. Ignore friction.
I_disk=0.5mr^2
KE_rotational=0.5*I*w^2
For part a I did...
KE=(0.5)(0.5)(400)(2^2)(pi/2)^2=987 J
For part b I did...
KE_i=KE_f
987 = 0.5(100)(2^2)(w^2) + 0.5(0.5)(400)(2^2)(w^2)
and get w=1.3 but the answer is supposed to be 1.0. Is mr^2 the correct way to do the kid's intertia?
Why do you think that kinetic energy will remain the same?
What physical quantity you are sure that will remain constant? Maybe angular momentum, who knows!?
Yes, think about what gyro is stating.
Also, your KE eqn is incorrect, there should be an omega squared. You seemed to take this into account in your soln. though.*edit* it is fixed now
Used conservation of angular momentum and got the correct answer. Though, why is KE not conserved?
Thanks,
Brandon
When the kids jump to the merry-go-round they exert forces on it. Forces cause change in kinetic energy, do not they?
