Mesh Analysis - Super Loop Question
The discussion focuses on using mesh analysis to solve a circuit problem involving a current source between two loops. The main confusion arises from how to treat the current in the loops, particularly whether to assume the current in both loops is equal to 6mA or to express it as I2 - I3 = 6mA. It is clarified that the two loops should be treated as a super loop, allowing for the application of Kirchhoff's Voltage Law (KVL) while ignoring the segment with the current source. Participants emphasize the importance of setting up equations correctly to solve for the unknown currents, ultimately leading to the calculation of Vo. The conversation highlights the systematic approach needed for mesh analysis and the value of solving simultaneous equations for clarity.
verd
So here is what the problem states:
Use both nodal analysis and mesh analysis to find Vo in the circuit below.
http://synthdriven.com/images/deletable/EEN201-05.jpg
My confusion:
I'm okay with the nodal analysis, I'm just a bit confused with the mesh analysis...
I'm confused as to how exactly I should treat this. I've come in contact with super loops before, but never with more than two loops. Because the 6mA current source is right between what I have labelled as loop 2 and loop 3, I'm not quite sure what to do. Would it be safe to assume that the current in both loop 2 and loop 3 is 6mA?
Or would I assume that I2-I3=6mA?
And if that's the case, in a 2-loop super loop situation, you would treat the entire circuit as one loop. In this situation, would you treat those two loops as one combined loop? As in would you go around that loop doing KVL in loop2+loop3 excluding loop 1?
Any help is appreciated!
Thanks!
My confusion:
Thanks!
Recall what mesh analysis is. It really still is KVL, KCL.
So if we examine the node on the far right, (with the 6mA flowing into it, the 12k attached to it, and the voltage controlled voltage source) what can we gather about it.
Recall KCL.
current in equals current out.
So what is the current flowing into it?
You have 6mA flowing in, and you have labeled I3 flowing into it, and I2 flows away (as you have labeled it).
So:
6mA + I_3 = I_2
You questioned yourself with:
(I_2 - I_3)=6mA
Notice if you add I_3, your expression becomes:
6mA + I_3 = I_2
Hey,
Thanks for your response... I understand that, thanks for confirming... However, what the big issue is is whether or not to treat it like a super loop problem... In super loop problems, you typically come up with an expression for the current source in between the two loops, as we did, (I2-I3=6mA), and then you work around that segment. You make the two loops into one large loop by sort of ignoring the segment in between.
Would I do the same thing here?... And should I ignore loop 1?
Can someone assist in setting up the equations?...I guess I have quite a few questions about how to correctly set up those equations.
Thanks
verd said:
Hey,
You didn't seem to, since you said
Back to the equations.
You can do a loop in 1, because those are all voltage sources.
Then you can loop from the bottom left corner, to top left corner, to top right corner, to bottom right corner right? because those are also voltage sources. Then you need an expression for Vx.
You find the current in Vx in a similar method as you did for the 6mA part.
You know the question is going to be a system of equations. Using analysis techniques, how much information can you pull from the network? Each loop gives you a piece of the puzzle. As long as you are following the rules to grab information, grab as much as you can until you have,
n equations
with n unknowns.
No, surely you can't.
Yes, that would be correct.
Yes, you will treat loops 2 and 3 as one single superloop. And you will go around this loop (as you do with loop 1) taking the KVL and ignoring the 6mA segment between the two loops. Try coming up with the KVL equation for the superloop on your own and I will tell you if you are on the right track.
Phew... Okay. Thank you VERY much doodle...
Here's what I've done... Could you please please glance over this and help me to make sure I'm thinking about this circuit correctly??
This is it (LONG PROCESS, sorry):
V_{x}=(I_{1}-I_{2})4k
Super loop btwn loop 2&3:
I_{2}-I_{3}=6mA \longrightarrow I_{2}=6mA+I_{3}
Super-loop Loop Analysis:
(I_{2}-I_{1})4k+(I_{3}-I_{1})8k+6V_{x}+I_{2}(12k)=0
(6mA+I_{3}-I_{1})4k+(I_{3}-I_{1})8k+6[(I_{1}-6mA-I_{3})4k]+(6mA+I_{3})12k=0
6mA(4k-24k+12k)+I_{1}(-4k-8k+24k)+I_{3}(4k+8k-24k+12k)=0
6mA(-8k)+I_{1}(12k)+I_{3}(0k)=0
I_{1}=\frac{6mA(8K)}{12K}=4mA
loop 1:
I_{1}(12k)+(I_{1}-I_{3})8k+(I_{1}-I_{2})4k=0
4mA(12k+8k+4k)+I_{2}(-4k)+I_{3}(-8k)=0
So, because I've found I1, I have two unknowns, I2 & I3... (I used my answer for I1 in the above loop 1 equation.)
Going back to the first statement, that leaves me with two equations and two unknowns:
I_{2}(4k)+I_{3}(8k)=4mA(24k)
I_{2}+I_{3}(-1)=6mA
Solving with my simultaneous equation solver, I get:
I_{2}=12mA
I_{3}=6mA
And finding Vo:
V_{0}=I_{2}(12k)=(12mA)(12k)=144VI mean, logically, from my understanding, I'm doing everything correctly. (I think)... It's just that 144v seems kind of high. I don't know, is this correct?
I know it's a lot of steps, I'm sorry...
Yup, that's right. If you don't mind me saying, a more systematic approach is to take KVL for loop 1 and the superloop and combine that with the current equation for the 6mA to give you three equations which are solved simultaneously.
This is what I meant...
Loop 1: 24 I_1 - 4 I_2 - 8 I_3 = 0[/tex]<br /> <br /> Loop 2-3: -12 I_1 + 16 I_2 + 8 I_3 + 6 V_x = 0 \Longrightarrow 12 I_1 - 8 I_2 + 8 I_3 = 0<br /> since V_x = 4(I_1 - I_2)<br /> <br /> 6mA: I_2 - I_3 = 0<br /> <br /> Solving these three equations simultaneously for the three unknowns gives the desired mesh currents (in mA).<br /> <br /> One last note; it should not be too difficult coming up with the mesh equations without actually starting with<br /> (I_{2}-I_{1})4k+(I_{3}-I_{1})8k+6V_{x}+I_{2}(12k)=0<br /> If you are astute, you would observe a certain <i>pattern</i> to which how these equations are formed.
Also, it is probably worth your time (if you are going to be doing a lot of these), to either learn how to setup a system of equations in matrix form and solve it with your calculator.
  • · Replies 187 ·
58K
