Metamaterials with epsilon and/or mu < 0.
  • Thread starter Thread starter yavuznuri
    Epsilon
Metamaterials with negative permittivity (epsilon) and permeability (mu) are being explored for their unique properties, as all known natural materials have positive values. These materials can theoretically exhibit a negative index of refraction, leading to phenomena such as reversed light propagation, where group and phase velocities diverge. The creation of such materials typically involves configurations like split-ring resonators and conducting wires, allowing for negative values of epsilon and mu. While the concept of light "going backwards" is debated, it aligns with established electromagnetic principles. The potential applications of these metamaterials include invisibility and advanced optical technologies.
yavuznuri
All known natural materials have epsilon and mu > 0. However, there is an intense effort to manufacture so-called metamaterials, where both of these are <0. In such a case, given n = sqrt[epsilon x mu], one would take the negative root and n is still a real number, but n <0 why do we take the negative?
What is so interesting about this?
What does this say about the propagation of v=c/n, does this mean light is going backwards?
n= √µϵ
n= √(-1) √-1
n= ί ί
n = -1
substances with negative µ and ϵ have some properties differnt from those with positve µ and ϵ and materials eith both µ & ϵ negative are not naturally found .
wavevector is in the direction of phase velocity, it means left handed materials have negative group velocity
There is a paper about invisibility which mentioned metamaterials. You said these materials have an index of refraction -1, Does this really mean that light goes backward when it reaches the metamaterial?. Is this really possible?? How could someone create a material with such properties??
yes in microwave region , electromagnetic wave bends once it reaches to metamaterial .
The phrase "light goes backwards" is somewhat arbitrary because light possesses two velocities, group velocity and phase velocity. A negative index means the group velocity is in the opposite direction to the phase velocity. It is entirely consistent with the laws of electromagnetism as far as I know.
The basic configuration for negative index materials is a layer of split-ring resonators (for negative mu) interspersed by layers of parallel conducting wires (for negative epsilon). The (narrow) wavelength range over which negative refraction is attained depends on the size of the resonators.
Claude.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
