Proving Metric Space: (X,\bar\rho) is Positive Definite
boneill3
Prove that if (X,\rho)is a metric space then so is (X,\bar\rho), where
<br /> \bar\rho:X \times X \Rightarrow R_{0}^{+}, (x,y) \Rightarrow \frac{\rho(x,y)}{1+\rho(x,y)}.<br />
I'm trying to prove the axiom that a metric space is positive definate.
because given (X,\rho) is a metric space is it enough to say that (X,\bar\rho), cannot be &lt; 0 because (X,\rho) cannot be &lt; 0 ? ie the limit of (X,\bar\rho) is 0 as (X,\rho) tends to zero ?
Yes, if x is not y, then <br /> \bar\rho<br /> is greater than 0 since <br /> \rho<br /> is greater than 0 for this case.
If x=y, then it is clear that <br /> \bar\rho<br /> is 0 as you have <br /> \rho(x,x)<br /> <br /> = 0 in the numerator.
Thanks for your help.
I have also got to prove the following
Let (Y, \theta) be a metric space. Prove the following.
f : X \rightarrow Y is continuous with respect to \bar\rho if and only if it is continuous with respect to \rho
I know I have to show that the inverse of Open sets in Y are open in X and visa versa how ever I'm not sure how to represent the open sets in \bar\rho
ie if I was proving (X,\rho) and (Y,\theta)
I would show that for each G \subseteq Y that f^{-1}(G)is an open \subseteq X whenever G isan open subset of Y
As the metric space \bar\rho uses the metric \rho how to I incorporate that into the proof ?
Let f be continuous wrt <br /> \rho<br /> and let G be open in Y. Then, as you pointed out, <br /> f^{-1}(G) <br /> is open in X. Let a be a point in <br /> f^{-1}(G) <br /> = A. Then, A is open in X implies that neighborhoods of a are in A (under the rho metric). Write out what these neighborhoods look like. They look like {y | ||a-y||<br /> \rho<br /> < e }, and these neighborhoods are in X. Now what do the neighborhoods look like under the <br /> \bar\rho<br /> metric and how do they relate to the usual neighborhoods?
Does this look alright ?
I've tried to use Open balls of radius \delta and \psi
So I have three metric spaces
(X,\rho)
(X,\bar\rho)
and
(Y, \theta)
and a function
f : X \rightarrow Y
which is continuous wrt (X,\rho)
So given f : X \rightarrow Ycontinous wrt \rho.
Take a neighbourhood B_{\rho}(a,\delta) = {x \in X \mid \rho(x,a) &lt; \delta }
Then for each \epsilon &gt; 0<br /> there is an \delta &gt; 0
Such that we have B_{\rho}(a,\delta) \leq \theta(f(x),f(a)) &lt; \epsilon As f is continuous
To show that f : X \rightarrow Y is continuous wrt \bar\rho we need to to find a B_{\rho}(b,\psi) \subset B_{\rho}(a,\delta)
So we can take \psi = \delta - \rho(b,a)
if
\rho(x,b) &lt; \psi
then
\rho(x,a) \leq \rho(x,b)+\rho(x,a)
\rho(x,a) &lt; \psi+ \delta - \psi = \delta
So we can know show that:
0 &lt; B_{\bar\rho}(x,\psi) &lt; \rho(f(x),f(b)) \leq B_{\rho}(a,\delta) \leq \theta(f(x),f(a)) &lt; \epsilon
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
