Microscopic difference between gas and liquid
The discussion revolves around the phase transition behavior of gases and liquids, particularly the microscopic differences between them. It highlights that while transitioning from liquid to gas can occur continuously, there is ambiguity in distinguishing them microscopically, as both are classified as fluids. The conversation also touches on the critical point, suggesting that the lack of a clear microscopic model for phase changes presents an intriguing challenge. Participants express frustration over the ambiguity in existing literature regarding these transitions. Ultimately, the renormalization group is noted as a useful tool for understanding universal behavior near critical points.
jostpuur
I am familiar with Ising model, and the phase transition behavior the interacting "arrows" attached to lattice points exhibit. Now, I'm curious to know if similar theoretical models exist of more concrete examples. For example, what is the microscopic difference between gas and liquid? Can the condensation and vaporization be understood through the use of some renormalization techniques?
Unfortunately no, as you can move continuously from liquid to gas (by going around the triple point on the phase diagram). Since there is no transition along this path, it suggests there is no way to distinguish them microscopically... they are just both fluids.
You probably meant the critical point, and not the triple point?
I see that it is possible to go from gas to liquid smoothly, but on the other hand, it is also possible to go from gas to liquid abruptly, so there must be some clear microscopical difference. This is a kind of thing, where it is frustrating that many sources merely mentions various things, leaving it ambiguous what is really known and what is not known. If it is the case that there is no microscopic theoretical model about the phase change between gas and liquid, it is of course very exciting, because one should consider it as a challenge :-p But I would prefer being more certain about it...
The best analogy I've hear is it's like a wall between 2 rooms, but the wall has a gap at the top. Is it 2 rooms or one room?
The renormalization group is applicable to universal behavior near the critical point.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
