Minimal coefficient of friction
The discussion centers on calculating the minimal coefficient of friction for a rectangle held by a rope and friction against a wall. Initial calculations yielded a coefficient of 0.15, which was questioned due to potential errors in determining the center of mass (CoM) distance from the wall. A revised calculation suggested that the CoM distance should be 0.58 times the side length, leading to a new coefficient of friction of 0.3. Participants debated the accuracy of the geometric assumptions and calculations involved. The conversation highlights the importance of precise measurements in physics problems.
Karol
The rectangle in the drawing is held by the horizontal rope and the friction on the wall.
What's the minimal coefficient of friction
Friction force: f=μN
Moments round the point of contact with the wall. the side of the rectangle is a, half the diagonal to the center is ##\sqrt {a}##. the distance of the CoM to the wall: ##\sqrt {a}\cdot\sin 55^0=1.16a##
$$1.16a\cdot mg=T\cdot \sin 10^0\rightarrow T=6.68mg$$
$$6.68mg\cdot\mu=mg\rightarrow\mu=0.15$$
It should be 0.3
So from the wall to the center of mass is 1.16 times the length of a side ? That's in mid-air ! ;)
Is it a square or rectangle? If it's a square check your calculation for "half the diagonal".
I thank you very much BvU for i didn't laugh so much for some time
I believe what you used for the normal force is incorrect.
The distance of CoM from the wall: ##\frac{a}{\sqrt{2}}\cdot\sin 55^0=0.58a##
$$0.58a\cdot mg=T\cdot \sin 10^0\rightarrow T=3.41mg$$
$$3.41mg\cdot\mu=mg\rightarrow\mu=0.3$$
