What Are the Optimal Kicking Angles for a Field Goal in Football?
The discussion focuses on determining the optimal kicking angles for a football field goal, specifically from a distance of 50 meters with a goalpost height of 3.44 meters. The kicker's initial speed is 25 m/s, and the equations of motion are applied to find the angles. The user initially struggles with calculations due to a calculator error but eventually resolves the problem after resetting the device. The correct angles for scoring are identified as 31 degrees and 63 degrees. The thread highlights the importance of accurate calculations in physics problems related to sports.
H2Owned
a football kicker can give the ball an initial speed of 25m/s. what are the least and greatest elevation angles at which he can kick the ball to score a field goal from a point 50m in font of the goalposts whose horizontal bar is 3.44 m above the ground.
d = Vit + 0.5at^2
Dx=distance in x direction
Dy=distance in y direction
and so on for Velocity and Acceleration
V = 25m/s
Dy = 3.44m
Vx = 25cos(theta)m/s
Vy = 25sin(theta)m/2
Ay = -9.8m/s^2
t = (Dx)/(Vx) = 50m/(25cos(theta))s
Now plug everything into an equation for Dy
Dy = Vy*t + 0.5Ay*t^2
3.44 = (25sin(theta))(2/cos(theta)) + 0.5(-9.8)(2/cos(theta))^2
I cannot get an answer for theta out of this equation..
The proper answers are 31 degrees and 63 degrees but i dot know how to solve it
nevermind i think i solved it. my calculator had a setting messed up somewhere that i couldn't find and kept giving me errors.
i reset my calculator and was able to solve it.
