Modulation of waves (Communication Systems)
The discussion focuses on the modulation of waves in communication systems, specifically comparing the characteristics of transmitted and received waves. The original poster questions the implications of the output wave's phase being confined to one quadrant, unlike the input wave, which crosses the time axis. They inquire if this arrangement can convert AC to DC and whether the phase change affects efficiency, particularly in voice signals. Additionally, there is confusion regarding the role of transducers in communication systems, with a request for clarification on their use in both wired and wireless systems. The conversation emphasizes the importance of understanding wave behavior and the components involved in modulation and demodulation processes.
Prashasti
Please look at the attachments below.
I shall use the word "modulation" instead of "amplitude modulation" since I've been taught about AM only.
So, my question is, in the first image (that I've attached), the messenger wave (which is modulated with the high frequency carrier wave) as well as the modulated wave, both are shown to be varying with time - and their phase is also changing (just like ALTERNATING CURRENT).
So, this is the wave which is transmitted.
But, in the second image - which shows the fate of the transmitted wave after being received by the receiver antenna- the output wave is shown to be varying with time - but its phase is not changing (i.e. The variations are limited to one quadrant only - above the axis only ) - just like time varying DC.
So, 1) Can the arrangement be used to convert AC into DC?
2) Is the change acceptable? I mean - the input wave's phase was changing - but it is not so with the output wave. So, will it affect the efficiency? Like- in the case of a voice signal?
The amplitude modulated signal received with the antenna, goes through a rectifier which transmits only the positive half of the signal. (The rectifier can be a diode, which transmits that part of the signal which makes the diode open ...) The result is a fast varying signal, with slowly changing height. Using a low-pass filter, it removes the high frequency component and you get the demodulated signal, that corresponds to the modulating one.
Likes Prashasti
There is no changing phase shift in the AM signal that I can make out, not like in FM. The demodulation block diagram applies to the AM signal, and shows the negative half of the waveform being removed, followed by filtering. The filtering function can even be considered to be performed by the audio amplifier or the loudspeaker, since neither will respond to the RF component in the rectified wave.
Likes Prashasti
I got the point. But still I think I didn't get the answer of the 'original' question. Actually, I'm trying to say that in the second diagram, all the oscillations are confined to one quadrant only - I mean, the wave is not "crossing" the time axis...Whereas in the first one, it can be seen actually crossing the time axis and entering in a different quadrant (like a sine wave).
And please help me with my first question too...(marked as 1) in the original post).
If this question seems to be pointless - then please explain the working of a transducer..Since It's not clear to me.
Is an electrical transducer used only in the case of a communication system involving cables (eg. The 'basic' telephones - landline) or is it also used in the systems involving EM waves transmission (eg. Mobile phones)?
A capacitor will remove the DC component and return the recovered message wave to being centred on zero. Most audio amplifiers have capacitive coupling, so the DC component is removed there, if not before.
Likes Prashasti
Sorry, I don't understand this. Perhaps you mean "modulator" (or maybe "detector") where you wrote "transducer"?
