- 8,142
- 1,756
http://www.jmeagle.com/plastic-pipe/pvc-pipe/ultra%20blue.htmlPVC (MO) stands for Molecular Oriented Poly(Vinyl Chloride).The process of molecular orientation has long been used to strengthen many materials. Ultra-Blue is manufactured by a process that reorients the molecules of conventionally extruded PVC pipe. The pipe, approximately half the diameter and twice the wall thickness of the finished Ultra-Blue product, is placed inside a mold sized to the proper outside diameter of the finished product. The temperature of the pipe is raised to the appropriate level for expansion and internal pressure is applied. This internal pressure causes the pipe to uniformly expand to the inside dimensions of the mold. The mold is designed so that during the process, the bell and gasket groove are also formed, producing a high quality bell. During the pipe expansion process, the molecular orientation is changed and the physical properties of the finished pipe product are established.
Improvements in design and physical properties include:
Non-Corroding
Ductile Iron Pipe O.D.
Larger I.D. than Ductile Iron and Convential PVC
Lighter weight than Ductile Iron and Convential PVC
Higher Impact Strength
Greater Cyclic and Hoop Strength
Higher Design Stress
Superior Notch Resistance
One of the Safest and Easiest Pressure Pipes to Tap
Thicker Walls than all PC 350 and Special Thickness
This is a product that I helped to develop. The expansion process is terribly tricky but we finally nailed it!
It always gives me a thrill to see these things hit the market.
