Molecule size of water and oxygen
  • Context: High School
  • Thread starter Thread starter Coda
    Molecule Oxygen Water
The discussion revolves around the comparative sizes of water and oxygen molecules, as well as the feasibility of separating these two substances using a material that allows one to pass through while blocking the other, potentially through an osmosis-like effect.
  • One participant asks which molecule is larger and requests the size units for both water and oxygen molecules.
  • Another participant provides a calculation suggesting that the volume of an oxygen molecule is approximately 1.56 times that of a water molecule, based on their molecular weights and densities.
  • A different participant argues that calculating molecular sizes may not be the best approach for finding a suitable material for osmosis, noting the different geometrical shapes of the molecules and the challenges posed by molecular interactions with potential membrane materials.
  • This participant suggests that a membrane with specific chemical properties, such as being hydrophobic, might be more effective for the intended separation.
Participants express differing views on the relevance of molecular size in the context of separation materials, indicating that there is no consensus on the best approach to achieve the desired separation.
There are unresolved assumptions regarding the effectiveness of various membrane materials and the complexities of molecular interactions that may affect the separation process.
This discussion may be of interest to those exploring molecular chemistry, separation techniques, and the properties of different substances in relation to their molecular structure.
Coda
Which size of the molecule is bigger? Water or oxygen?
Can someone state out the size unit of these molecules
And, can I find a meterial to separate this 2 matter but let one of it pass through the other? (Osmosis effect)
Really appreaciate who can help out here, thx
The density of water is 1kg/L and that of liquid oxygen is 1.14kg/L. The molecular weights are 18 and 32 respectively. So I reckon the volume of an oxygen molecule is about 32/(18*1.14)=1.56 times that of water. The exact volume of each molecule can be calculated using Avagadro's constant and the above data. If the molecules are assumed spherical, apply a factor of [tex]\frac{\pi}{3\sqrt 2}[/tex] for closely packed spheres and you can find out the radius.
Can't help with materials for osmosis.
Wai Wong
I think to find the material for your osmosis purpose, calculating the 'sizes' of the molecules is not the right approach because they are of comparable volume but different geometrical shapes - oxygen molecule like a dumbbell and water molecule like a V shape. If a material have holes slightly bigger than an oxygen atom it should theoretically allow the passage of oxygen molecules but not water, but actually very few oxygen molecules are aligned in the right direction to get through. Also atom and molecules have fuzzy boundaries and the electron cloud of oxygen/water molecules will interact with that of the material around the hole, making passage difficult. If some or all holes are any larger, both molecules can get through. So a traditional approach of finding the membrane material may not work.
I suspect permeable membrane with certain chemical properties (e.g. hydrophobic) may do the trick. You may want to seek help in chemistry forums.
Wai Wong
Hey, thanks for your reply.
It really helps a lot :)
  • · Replies 17 ·
