Master Moment of Inertia with Integration: Rod, Disk & Center Axis Solutions
The discussion focuses on finding the moment of inertia using integration for a rod and a disk with varying density functions. The correct expression for the rod's mass per unit length is clarified as λ=λ₀|x|, leading to the moment of inertia result I=1/8 ML². For the disk, participants discuss using polar coordinates to solve the problems, emphasizing the importance of the area element dA=rdrdθ. The conversation highlights the confusion caused by potential typos in the professor's assignments, but participants provide helpful guidance to each other. Overall, the thread illustrates the collaborative effort to understand complex physics concepts related to moment of inertia.
acgold
I've been doing moment of inertia problems and haven't had any trouble so far until these:
Using integration, find the moment of inertia of a rod about an axis through its center if the mass per unit length is \lambda=\lambda_o x. The answer is supposed to come out to I=\frac 1 8 ML^2.
Using integration, find the moment of inertia of a disk of radius a, about its center if a) \sigma=\sigma_o r^{-1} b) \sigma=\sigma_o r^2. The answers are a) I=\frac 1 3 Ma^2 b) I=\frac 2 3 Ma^2
Even with the answer I'm confused :confused:. Please please help me out...thank you.
Okay, I'll do the first one for you.
The line density is given as \lambda=\lambda_{0}x
It's no wonder that you are stuck with this exercise, because this expression is by itself meaningless.
The correct expression must be:
\lambda=\lambda_{0}|x|, -L/2<=x<=L/2
i.e the absolute value of x, rather than x itself.
(I assume you gave us ALL the information present in the exercise?)
We gain:
I=\int_{-\frac{L}{2}}^{\frac{L}{2}}\lambda_{0}|x|{x}^{2}dx=\lambda_{0}\frac{2}{4}(\frac{L}{2})^{4}
The mass M of the rod is readily calculated:
M=\int_{-\frac{L}{2}}^{\frac{L}{2}}\lambda_{0}|x|dx=\lambda_{0}(\frac{L}{2})^{2}
Combining the expressions yiels the desired result.
Thank you thank you thank you...I've been working on that problem for hours. Yeah I gave you ALL the information I had. My professor is notorious for having typos. I did the first problem the way you showed me and I understand it 100% now. I'm off to work on the last two on my own...thanks for all your help. BTW, how did you know it was the absolute value of x? Do the sigma expressions require absolute values also? Thanks again.
My reasoning was as follows:
1. Density has to be non-negative.
Hence, the only meaningful interpretation of the given expression as it stood, was that x is measured from one end of the rod (x=0 at one end) , but that does not give the stated expression.
2. Hence, I assumed that the density functionshould bemeasured from the point of the rotation axis, but then I had to introduce the absolute value in order to have a meaningful density function.
3. As to the area densities, I don't think so, since the radius pr. definition is non-negative (I haven't checked them yet)
Thanks, you're a much better teacher than my professor. :) I've been working on the second problem for a few minutes now and I'm stuck again. Maybe another typo...I don't know but I'll keep trying it.
Well, thanks for the compliment, :smile:
(But there has to be a good reason why he's a professor, and I'm not!)
Your professor has the second problem right.
In order to solve it, you must use polar coordinates!
Remember that the proper area element, dA, has the form: dA=rdrd\theta,
with the limits:
0\leq{r}\leq{a},0\leq\theta\leq2\pi
Good luck!
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
