Moment of Inertia of a hollow beam inside a rubber shell
The discussion focuses on calculating bending and shear stresses in hollow beams, specifically regarding a steel shell encased in rubber discs for impact loading. The user initially questions whether to consider only the steel shell's moment of inertia in their calculations, given that the rubber is meant to distribute loads more evenly. However, they later realize that the rubber's contribution to the overall moment of inertia, particularly in terms of rotational inertia, is significant due to its mass and radius. The conversation highlights the complexity of composite materials, noting that while the rubber may not significantly contribute to bending stress, it does affect the overall stiffness and rotational inertia of the system. Ultimately, the user seeks clarity on how to incorporate these factors into their calculations.
MaxOtis
Hello guys,
I am calculating Bending and Shear stresses in hollow beams. We have a particular kind of shell that we use for impact loading, so we put rubber discs around the steel shell.
So my question is, how will it affect the moment of inertia ? Since I know that the rubber discs will resist to the stress, can I consider only the steel shell in my calculations ?
What do you guys think ?
Thanks.
You need to provide considerably more information for anyone to make a sensible comment.
In particular why do you think the disks act compositely with the steel?
Thanks for your reply,
I attached a pdf of an impact roller.
The roller is use in conveyor to carry ore/material. More specifically, we use it where we drop the material on the belt.
The reason why we use rubber is to make the load more uniform on the steel shell, without it, their would be huge concentrations of load on small area on the shell and it wouldn't resist a day.
Even with the rubber, the quantity of load supported by the steel shell is obviously the same, and if we make a Free Body Diagram of only the steel shell, I could take the Moment of Inertia of the shell without rubber. Am I right?
EDIT: After consideration, it doesn't really make sense to consider the load only on the steel shell. I am out of idea. The minimum Inertia would be in between 2 rubber discs, but since the load are applied on the top of the discs, I am not sure whether it is assumption to use this value of Inertia for my calculations.
Any Idea ? :rolleyes:
OK I think you are talking about rotational inertia.
My earlier comment was directed on the assumption of structural bending of the roller.
For rotational inertia the rubber will add significant mass at a significant radius to greatly increase the rotational inertia about the shaft axis.
I assume there is no slip on rotation.
In terms of adding to the shaft stiffness against bending I doubt that even if the rubber was sufficiently shrunk on to the steel to act compositely it would attract much stress, despite its position) simply because of the huge difference in elastic moduli.
Is this making progress?
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
