Moment of inertia of a rotated line
rock.freak667
I have a drum that comprises of basically a cylinder and rotated line in the form y=mx+c
http://img22.imageshack.us/img22/6108/druma.jpg
I=\int r^2 dm
I found the MOI for the cylinder as 1/2M(a2+b2) where a and b are the inner and outer radii respectively.
I am getting trouble forming the MOI for the line. I am supposed to consider an elemental section, but I am not sure if I should consider a disc or some other shape.
Disc: (Width dx and radius 'y')
dI=1/2(dm)y2
dm=ρ dV = ρ(πy2dx)
dI=1/2ρπ y4 dx
I_{line}= \frac{1}{2} \rho \pi \int_{x_1} ^{x_2} y^4 dx
Since I have two lines, the inertia would be
I = \frac{1}{2} \rho \pi \int_{x_1} ^{x_2} (y_2^4 -y_1^4) dx
I can appropriately select x2 and x1 based on height of the cylinder and the height of the total drum. I can find the ρ for the material. But I'd need to calculate the equations for y2 and y1.
So my MOI would be
I = \frac{1}{2} M(a^2+b^2)+ \frac{1}{2} \rho \pi \int_{x_1} ^{x_2} (y_2^4 -y_1^4) dx
Is this correct or did I make a mistake in my element or in the algebra?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
