Calculating Moment of Inertia for Rectangular Plate | Center & Corner Axis Proof
The moment of inertia for a rectangular plate with mass M and sides A and B about its center of mass is calculated as (1/12)M(a^2 + b^2). To find the moment of inertia about an axis perpendicular to the plate through one corner, the parallel axis theorem is applied. This theorem states that I = I (at center of mass) + Md^2, where d is the displacement. The displacement is determined to be half the diagonal, calculated as (a^2 + b^2)/4. By combining these equations, the moment of inertia about the corner axis is confirmed to be (1/3)M(a^2 + b^2).
johnnyb
I have to show what the moment of inertia of a rectangular plate with mass M and sides A and B is about its centre of mass. I have come up with
\frac{1}{12}M(a^2 + b^2)
Now I have to show what the moment of inertia of the same plate is except this time about an axis perpedicular to the plate and passes through one corner. I know it is:
\frac{1}{3}M(a^2 + b^2) But having some problems proving it
Yes it is.
I = I (at centre of mass) + Md^2
But I can't see how that can get me from the first to second equation
Easy,
I_{cm} = \frac{1}{12}M(a^2 + b^2)
The displacement is half the diagonal, that is,
\frac{a^2 + b^2}{4}
So add them up and you get:
I = \frac{1}{3}M(a^2 + b^2)
:smile:
Steiner's theorem.That's the name i learned once with the theorem itself...
Daniel.
