Moment of inertiaFind the moment of inertia of the plate
To find the moment of inertia of a parabolic plate about the y-axis, the correct integration method involves calculating the area first, using the formula for the area of the plate and integrating the parabolic boundary. The initial attempt to integrate and multiply by mass did not yield the correct moment of inertia. Clarification on the plate's contour, which consists of straight lines and a parabolic arc, is necessary for accurate area computation. A visual representation may aid in understanding the problem better.
Punchlinegirl
A uniform plate of height H=1.60 m is cut in the form of a parabolic section. The lower boundary of the plate is defined by: y=1.75x^2. The plate has a mass of 4.94 kg. Find the moment of inertia of the plate (in kgm^2) about the y-axis.
I integrated 1.75x^2 to get .583x^3. Then put 1.60 in for x and multiplied by the mass 4.94. I got 4.02 kgm^2 as my answer, which isn't right. Can someone help?
I have good reasons to believe that
I_{y}=\frac{M}{S}\int_{0}^{1.6} dy\int_{0}^{\sqrt{\frac{y}{1.75}}} x^{2} \ dx
The area of the plate is
S=S_{rectangle}-\int_{0}^{l_{x}} \left(1.75x^{2}\right) \ dx
,where l_{x} is the "x" coordinate of the point obtained by projecting the point of coordinates
\left(\sqrt{\frac{1.6}{1.75}},1.6\right)
onto the Ox axis...
I hope u see which rectangle I'm talking about.
Daniel.
I'm sorry but I have no idea what you've done in this problem...
U've got a plate whose contour is made up of 2 right lines and an arch of a parabola...U have to find the plates' area which will be needed to evaluate the moment of inertia.
Make a drawing and see how u can compute that area...
Daniel.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
