Forearm Homework: Finding Forces, Tension, Moment WRT Elbow Point E
  • Thread starter Thread starter Ronaldo95163
    Moments
The discussion focuses on calculating forces and moments in a human forearm scenario involving a girl lifting a dumbbell. Key points include the need to determine the force exerted by the muscle in the upper arm, the forces acting at the elbow point E, and the tension when the angle theta is 45 degrees. Participants emphasize the importance of using the correct approach to solve for unknown forces, particularly noting the mechanical disadvantage of the lever system. The conversation highlights the necessity of considering moments and forces acting at the elbow to arrive at accurate calculations. Overall, the thread provides insights into the complexities of biomechanics in lifting scenarios.
Ronaldo95163
Figure 5 below shows an approximation of the system of forces acting on the human forearm. The weight of the forearm is 25N and acts 15cm from the elbow of a girl lifting a dumbbell of weight 50N
Find the
1)Force, F, exerted on the human forearm by the muscle in the upper arm
2)Forces acting at the point, E of the elbow
3)Tension if theta is 45 degrees
sum of ACW = sum of CW
sum of upward forces = sum of downward forces
My Attempt is in the pictures below
Hi Ronaldo95163. You could use ∑ forces iff you knew the force acting at the elbow, but we don't know anything about force components at E (apart from the fact that they exist). So your first part is wrong. You will have to approach it differently.
In any case, because of the big mechanical disadvantage seen in this type of lever, you know that the upwards force needed close to the pivot point is going to be >> the two downward forces you have considered.
Thanks a lot man...wasn't sure if to consider thet force at E first...what I figured tho was that
Fsin70 = 75 + E
Solve for E using moments and then substitute it into find for F
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
