Momentum and acceleration due to gravity
The discussion centers on the relationship between momentum, gravity, and danger. Objects with greater momentum pose a higher risk due to their velocity, making them more dangerous than stationary objects. The correct formula for gravitational force is Fg = G m1m2/r^2, and when the radius is doubled, the acceleration due to gravity (g) becomes one-fourth of its original value. It is clarified that Fg is not the same as g; rather, g is derived from the gravitational force equation. Overall, understanding these principles is crucial for assessing danger in various scenarios.
pharaoh
what object is dangerous for the target, the one that has greatest momentum or the one that has least momentum and why? what is safest?
I answeres all the parts that contain momentum and velocity and force but i stucked in this one
also
what is the value of g (acceleration due to gravity) if the radius doubled?
is the right formula for this question is Fg= G m1m2/r^2, or do i have to substitute the Fg with m*a, then do the rest
Things with momentum are dangerous because it means they're moving. Are you more scared of a knife on a table or a knife thrown at you?
That equation you posted is correct. Everything should factor out leaving 1/(r^2). How does the gravity change when the r in 1/(r^2) is changed from 1 to 2, or from 2 to 4?
so you mean that Fg is the same as g right
and the object that has greatest momentum is the most dangerous
if i doubled the radius then the g= 1/4
No, Fg is not the same as g. From the equation, F=(Gm1m2)/r^2 which gives m2g=(Gm1m2)/r^2 and so g=Gm1/r^2
Correct
Right idea: the new value of g obtained when doubling the radius will be 1/4 times the old value of g. So, write g_{new}=\frac{1}{4}g
